Offline Mr. Ron
#1 Posted : 18 May 2021 19:10:03(UTC)
Mr. Ron
What is a good lubricating oil for locomotives that can be obtained locally (not from online stores)?
#2 Posted : 18 May 2021 20:20:06(UTC)
Hi Ron
During many years Märklin advised to use winter grade oil for cars.
Because now there is more and more non metal parts in gears, my personal choice for recent engines is to follow the manufacturers recommendations (avoid corrosive oils and "cleaning" or "derusting" oils)
On old Märklin motor oil for cars is good enough I think.
Anyway modern Märklin engines need such small quantities (using a syringe) that cost is not a decisive factor.
Offline Mr. Ron
#3 Posted : 19 May 2021 00:46:32(UTC)
Mr. Ron
Hi Ron
The reason why I ask is because if I need to use Marklin oil, I have to order it online and that takes many days to get. I need something I can get at my local store.
Offline skeeterbuck
#4 Posted : 19 May 2021 01:06:17(UTC)
skeeterbuck
Ron, I use Woodland Scenics products. These are available locally and are plastic compatible which I think is useful for today's Märklin products. I have the light oil and gear lube. The light oil I use for axles etc. Hope this helps!
https://woodlandscenics....tegory/PremiumHob-E-Lube
thanks 1 user liked this useful post by skeeterbuck
Offline Mr. Ron
#5 Posted : 19 May 2021 01:57:19(UTC)
Mr. Ron
Where I live, (south Mississippi), there are no hobby shops that sell Woodland products. Is 3 in 1 oil OK to use?
Offline skeeterbuck
#6 Posted : 19 May 2021 04:19:08(UTC)
skeeterbuck
I would NOT recommend 3 in1 oil because it's not plastic compatible. What type of oil do the hobby shops carry? I would think they would carry something that is designed for use on model trains. LaBelle is another brand that makes good hobby lubricants.
thanks 3 users liked this useful post by skeeterbuck
Offline Danlake
#7 Posted : 19 May 2021 08:57:15(UTC)
Danlake
I use the labella range of lubricants, but if you can’t get that go to a sewing shop and buy their most expensive sewing machine oil, which normally would be a synthetic based and safe on plastics.
In the old days, before manufactures made their own brands, many modellers would use sewing machine oil.
Best Regards
Lasse
thanks 3 users liked this useful post by Danlake
Offline Tom Jessop
#8 Posted : 19 May 2021 23:18:19(UTC)
Tom Jessop
I have been using Whal hair cutter lubricant . Light in color & also density so minimal amount to use . It is also used on running surfaces such as track , wipe on & then light wipe off .
Cheers Tom in Oz.
thanks 5 users liked this useful post by Tom Jessop
Offline 1borna
#9 Posted : 20 May 2021 21:23:33(UTC)
1borna
Croatia
Kerosene has an unpleasant odor, but similar in composition, the oil for kerosene lamps smells better and smokes fine.
I have been using it for years and have had no problems with constipation
thanks 3 users liked this useful post by 1borna
Offline Mr. Ron
#10 Posted : 21 May 2021 02:39:36(UTC)
Mr. Ron
Sewing machine oil or Whal oil sounds good to me. Thanks Lasse and Tom.
thanks 2 users liked this useful post by Mr. Ron
Offline dominator
#11 Posted : 23 May 2021 02:38:02(UTC)
dominator
I was given a litre bottle of fully synthetic engine oil. Seems ok to me.
Northland. NZ
Offline 1borna
#12 Posted : 25 May 2021 20:38:36(UTC)
1borna
Croatia
Oils for internal combustion engines contain various additives that are not needed for our models.
These oils are designed to change completely at certain intervals and in addition constantly pass through the filter.
With long-term use in models and in small quantities, the oil can dry out over time and then additives remain that can cause shafts and gears to lock - this was a regular case with old Marklin oil from the 50s to 70s!
thanks 4 users liked this useful post by 1borna
#13 Posted : 26 May 2021 08:10:39(UTC)
I used Märklin oil in the ’70s, then stored my rolling stock for 25+ years without ever using it. Took it out again early in this century and everything worked fine, nothing had hardened.
However, I had Märklin items from the ’90s, shelf-queens new from the dealer, where the motor had seized completely.
Long story short: My experience: Märklin oil from the ’70s is fine, but Märklin oil from the ’90s sometimes hardens quickly.
Online PJMärklin
#14 Posted : 26 May 2021 11:55:34(UTC)
Hello Tom,
May I ask, what oil do you use in 2021 ?
Philip
#15 Posted : 26 May 2021 12:19:38(UTC)
May I ask, what oil do you use in 2021?
About 15 years ago a Märklin dealer told me any oil was OK, except the Märklin oil.
He offered me Faller, Roco, and Fleischmann. I chose Fleischmann because I like the bottle.
I also use Roco grease.
Offline bph
#16 Posted : 26 May 2021 17:25:29(UTC)
The Roco grease is made by Klüber, according to the datasheet on modellbahnshop-lippe.com
And interestingly the Piko oil, is rebranded Sewing machine oil from https://www.hanseline.de/en/sewing-machine-oil/
So it seems that most model train oils and grease are just rebranded industry products in smaller and more expensive packing.
However one should be aware that mixing different oil or grease types/brands might in some rare cases cause a chemical reaction eg like hardening or separation.
One maker that has caught my interest is Super Lube: https://www.super-lube.com/oils They provide a good plastic and rubber Compatibility Chart.
Anyone who has experience with using Super Lube products on model trains?
#17 Posted : 26 May 2021 21:00:50(UTC)
I mostly use the Faller "Teflon-öl", but it of course fails on the local availability issue. Even use it for door hinges, locks and such at home - works very well.
I think a fully synthetic 5-40w or thinner motor oil would be rather ok also on plastic gears, but I will stand corrected if I'm wrong. Smile
#18 Posted : 26 May 2021 21:16:32(UTC)
s
I never observed this on my Märklin locos - more than 100 of them (the oldest were made before 1950) but I don't say it does not exist.
Here in Europe, few of those "oil seizing stories" are reported but elsewhere (US for sure, OZ may be) this has definitely to do with very hot climate and long inactivity periods.
My father was in the design and manufacturing of lubrication oil for cars. True they were (still are) adding components (chemicals) to improve lubrication, maintain viscosity through a wide temperature range and sometimes they were incompatible between various brands (causing chemical reactions when mixing). So for many many years the best advise by Märklin was to use regular winter grade motor oil. Some use sewing machine oil but usually its viscosity is much lower. The presently sold Märklin oil looks very much like sewing machine oil (transparent, low viscosity while the older Märklin oil (yellow, viscous) was definitely motor oil as for cars.
With the advent of plastic in gears, some oil qualities attacked the plastic. For Märklin it was not a major problem as most gears are made of metal The exception I know are the conic gears in locos like the Württembergerin 3611 or nylon in very early models (only one gear to reduce the noise in the 1950s ).
On its mechanisms Faller is advising to use non-acid oil.
Offline phils2um
#19 Posted : 27 May 2021 01:23:00(UTC)
phils2um
It is a bad idea to use any modern motor oil whether fully synthetic or not. They all have additives specifically designed for internal combustion engines that are not appropriate for electric motors not to mention plastics.
Phil S.
thanks 4 users liked this useful post by phils2um
Lubricating oil (Collector's Corner general)
by lmedberry 18/05/2015 07:09:28(UTC)
This page was generated in 0.907 seconds.
