Offline joyofmarklin
#1 Posted : 11 May 2021 23:44:37(UTC)
joyofmarklin
I had my blue 3039 converted to digital and a Marklin sound card was added.
However looking at the manual not all the effects match up. I have up to F23, but there are spaces. For instance my F4 is a long whistle, not the ABV off as in the manual. f18 to F23 are all announcements? f8 is also a station announcement? I was advised that the sounds were downloaded from Marklin.
Despite being a very young boy living in Berlin when the wall was built, my knowledge of German is very limited!
I am using a mobile station
Can anyone help in decoding my enigma please?
Many thanks
#2 Posted : 12 May 2021 00:10:19(UTC)
Obviously the sound project does not match the manual you are using.
Any function can be assigned to any key, so "ABV off" can be anywhere - if it is mapped at all.
With the MS2 you can change hardly anything and even investigating the current function mapping is a bit troublesome.
Which sound chip did you get?
Maybe the instructions for the sound project from the Märklin site will be of help.
Update: Sorry, the files on the Märklin site are not helpful. The person that programmed the chip should be able to provide some documentation.
#3 Posted : 12 May 2021 00:33:21(UTC)
As a minimum they should advise what project number they used. Using that the relevant info can be gleaned from the Marklin projects.
#4 Posted : 12 May 2021 01:58:06(UTC)
joyofmarklin
Many thanks for the his advice 😁
This page was generated in 0.292 seconds.
