Offline MartinS
#1 Posted : 05 May 2021 08:35:31(UTC)
MartinS
Hi forum members,
I have a 37940 SJ T44, which is equipped with the originally installed mfx decoder without sound. I would like to upgrade the decoder to an mSD/3 (using the standard diesel sounds, unless there is a T44 sound project out there somewhere for this decoder). I think I understand how I have to configure the decoder for the sine motor. But I don't know how to configure it to be able to control the front and rear lights, which can be set to 4 different configurations using combinations of f0, f1 and f2 in the original decoder.
I'm using the 60971 to configure the mSD/3, and I don't have a CS2 or CS3 to read out the configuration of the original decoder (I'm running my setup with LDT digital control equipment), which I guess would otherwise give me the information I need.
I'm still rather new to configure Märklin decoders (or any other decoders for that matter), so I am not entirely sure how the lights are controlled.. are the f0, f1 and f2 mapped to auxiliary outputs on the decoder to control the light combinations?
Martin
Offline g-gekko
#2 Posted : 05 May 2021 15:14:14(UTC)
g-gekko
I don't have the 37940, but as far as I can see AUX1 and AUX2 must be mapped to F1 and F2 while LF and LR are mapped to F0. I can't see any other possibilities since this locomotive certainly does not have SUSI functions. AUX3 and AUX4 as logical functions are needed to control the engine.
Märklin has a soundproject for the 37945 (T44 Green Cargo). That one does not have the C sinus engine, but have SUSI functions. I have cleaned up the project and added functions that should make the decoder work with the 37940 as I understand it's functions. Please have a look at it.
Leif
T44-376-SJ.zip (8,625kb) downloaded 12 time(s).
T44-376-SJ rev2.zip (8,625kb) downloaded 10 time(s).
Edited by user 09 May 2021 09:40:55(UTC)  | Reason: Not specified
Offline MartinS
#3 Posted : 05 May 2021 16:55:12(UTC)
MartinS
Hi Leif,
Thanks for the suggestions! I will play around with the mapping of F1 & F2 to Aux1 and Aux2 and see what happens.
Also, thanks a lot for the sound project! I will look into it once I get the lights sorted.
Martin
EDIT: I have now installed the decoder and also soldered the speaker to the circuit board. Works like a charm, both sound and the lights with F1 & F2 mapped to Aux1 and Aux2. So thanks again for the suggestion!
Will try your sound project next.
Edited by user 05 May 2021 22:10:06(UTC)  | Reason: Not specified
Offline MartinS
#4 Posted : 08 May 2021 19:38:10(UTC)
MartinS
Leif, I can report that your project works very well with the 37940, with two changes needed for the motor control:
Functions->Always->Output 3->Direction: Both (instead of Forward)
Functions->Always->Output 4->Direction: Both (instead of Reverse)
Offline g-gekko
#5 Posted : 09 May 2021 09:45:39(UTC)
g-gekko
Hi Martin!
Thank you for letting me know, I am so glad that it worked. I have updated the project in case someone else will try it.
Best Regards
Leif
This page was generated in 0.414 seconds.
