Offline fje
#1 Posted : 01 May 2021 18:12:54(UTC)
fje
Hello, I feel I have damaged the S88 input of my Intellibox I 65000Cursing
I will try to fix it, if it were possible, but the first thing I need is to open my Intellibox 65000 that I don't know how to do it. It seems there is some very old thread about it, but I am not able to find it or any that explain how to open it.
Any information about how to open my IB 65000 would be appreciated and, even much more any info about how to fix the S88 input/control of it.
Thanks, kind regards and take care.
Javier
#2 Posted : 01 May 2021 18:20:58(UTC)
Javier
From your description on the B&G I think the IC that was fitted to the s88 back to front is more likely to be damaged. I would replace that before attempting to repair the IB.
Offline fje
#3 Posted : 01 May 2021 18:31:42(UTC)
fje
Hi, thanks for your fast answer, and, yes, I replaced it but it didn't work. In fact I did more, I connected an old S88 I already had to the IB and, no way, the retro contacts weren't recognized :( So, I believe that the IB S88 input/control is damaged.
#4 Posted : 02 May 2021 04:07:26(UTC)
You might be referring to this old thread of mine, not the same issue, mine was the output stage, similar to what happens with the 6021 but might help you
https://www.marklin-user...Extern--Voltage---BUGGER
You'll have to drill small holes into the side-plugs holding the case together, then screw in a small self-tapper and pull the plugs, then you can carefully separate the upper & lower casing
My only advice is to take lots of photos as you go, you never know what you might need to refer back to.
Also, there's a couple of Groups that might be able to help and it looks like you've already found the IO group - https://groups.io/g/IBX
Good luck
Offline fje
#5 Posted : 02 May 2021 08:18:09(UTC)
fje
Cookee, yes, that is the thread I was looking for, thanks.
Good advise, photos, I use to do it, but it is a good reminder.
And I already put a question in the "new" IBX group in groups.io, but I didn't get answer yet....
Thanks again and enjoy your freedom of Covid-19 in NZ.
Javier
Offline fje
#6 Posted : 08 May 2021 21:38:47(UTC)
fje
Good news.
We (a friend of mine) were able to fix it. Problem was one of the integrated circuits at the S88 input, it was the one I "fried". Once it was replaced, S88 of the IB is working again.
thanks 1 user liked this useful post by fje
This page was generated in 0.360 seconds.
