Offline Lusito
#1 Posted : 22 April 2021 15:05:16(UTC)
Lusito
Hello
How do we connect the 74042 to the back of the Captura de Ecra (1163) - Copia_LI.jpg z21?
1-do we cut one end and make a connection to a green phoenix connector?
Also; how do you call a system that is composed of 3 rail C-track + z21 controller and software + Marklin 3 rail locomotives and Marklin rolling stock?
Thank you.
Best Regards
Lusito
#2 Posted : 22 April 2021 15:13:54(UTC)
Originally Posted by: Lusito Go to Quoted Post
How do we connect the 74042 to the back of the z21?
Cut the 74042 in the middle and you have two feeder wires. Use a plug at the end.
When the layout grows you can use a bigger bus wire. When you make your own feeder tracks, you can solder the blank ends to the tabs of the C track.
I would not trust the plug connections for C track that is glued or screwed to the layout.
A digital three-rail layout.
Offline Lusito
#3 Posted : 22 April 2021 15:26:13(UTC)
Lusito
Hello H0
Thank you very much for your reply.
Cutting the wire in 2 parts is a good idea!
Best Regards
Lusito
This page was generated in 0.246 seconds.
