Offline Airfix05
#1 Posted : 20 April 2021 17:03:56(UTC)
Airfix05
Ireland
Hi Forum members
May I first ask is it possible to reset your CS3 back to its factory settings?
At the moment my CS2 is constantly switching itself off to Red and I don’t know why ?
I’m sure I made a mess of something but I don’t know what, so I thought resetting the CS2 would allow me to start again.
PS I have unplugged the controller from the wall socket without success
Thank you
Airfix05
#2 Posted : 20 April 2021 19:06:38(UTC)
I believe you need to load the leer (empty) file to restore the CS3 to factory settings.
You go to System/Settings and push the Restore button
You will be asked to confirm
Then you are proposed a screen like this
Select the file Leer.zip
Warning: you may want to make a backup of the previous version of the CS3 prior to resetting to factory status
I am not sure to understand the relationship between the short circuit you have on your CS2 and the need to reset your CS3 to factory settings
Just in case you meant CS2 factory reset, here is how it goes:
  • select SETEUP
  • select data RESTORE
Then you have a screen like this
Select the file Reset_Maerklin.tgz and confirm
Edited by user 21 April 2021 00:10:09(UTC)  | Reason: Addition of CS2 reset
Offline PMPeter
#3 Posted : 20 April 2021 22:49:09(UTC)
PMPeter
Is the question about a CS2 or a CS3?
The title says CS2, yet the opening statement refers to a CS3 and so does JohnjeanB's response.
Offline Airfix05
#4 Posted : 20 April 2021 22:56:53(UTC)
Airfix05
Ireland
My Apologies I meant to say CS2 and not CS3.
#5 Posted : 21 April 2021 00:09:23(UTC)
Well my answer covers both cases (CS3 and CS2 - there was a doubtBigGrin )
This page was generated in 0.446 seconds.
