Offline trentschler
#1 Posted : 14 April 2021 18:05:01(UTC)
trentschler
Hi All,
I'm setting up a three-rail C-track digital layout with my CS3+ as the command station. My platform is already wired for four power distribution blocks from a previous DCC layout. The current command station (NCE) sends the signal to the track through DCC Specialties PSX circuit breakers. I'd like just to replace the output of the NCE system with the output from the CS3+. It would be DCC more or less, wouldn't it? As opposed to pure AC? I can rewire some bits if necessary and bypass the PSX units. Of course the CS3 would then be responsible for any and all the shorts. How are power districts commonly handled with Marklin three-rail? Separate booster districts? Obviously, this is my first layout other than a simple loop.
Thank you,
Tony
Offline rbw993
#2 Posted : 14 April 2021 19:30:53(UTC)
rbw993
Hi Tony
Are you planning to run DCC on the CS3+? That is no issue. Marklin does not warrant their devices to work with other brand accessories, but that doesn't mean they won't. Usually Marklin layouts use boosters to segment the layout into power blocks. If the PSX circuit breakers just pass through the signal with no modification it would probably work but total power usage will be limited by the CS3+. The CS3 manuals have diagrams of typical setups for connectivity to other Marklin devices and the track.
Roger
Offline trentschler
#3 Posted : 14 April 2021 20:06:10(UTC)
trentschler
Hi Tony
Roger
Yes, I'm planning to run only DCC, well, mfx actually, but I only have Marklin locomotives now. The PSX breakers just pass the signal on through. I've read that they work with ECos and pass through RailCom, so they should be OK with my CS3. My layout is not too big (around the walls 9' x 15') and I'll probably only run a few trains. I have both the smaller power supply as well as the larger one (and a booster for that). I just wanted to try some automation and Marklin makes that pretty easy because it's all one system. And, of course, the trains are cool.
thanks 1 user liked this useful post by trentschler
Offline rbw993
#4 Posted : 14 April 2021 20:58:16(UTC)
rbw993
Mfx is not DCC. It is Marklin's own command control implementation. DCC has some standards that are different. Too complex too get into but they can exist together on a layout.
#5 Posted : 14 April 2021 21:16:47(UTC)
Correct, and the CS3, and MS2 sold for Trix (and cs3 for LGB except power pack) are identical. Both multi protocol. You can even run other brands of locomotives, ESU, Piko, Roco, etc if DCC equiped. You only need to manually enter the loco into your CS3 once. The Roco Z21 cab driver function will only work with a Z21, or possibly an ESU Ecos. The marklin mfx software/firmware and CS3 is not Railcom compliant. If you desire the "world of operation" feature, you have to buy a Marklin locomotive.
Offline michelvr
#6 Posted : 14 April 2021 21:28:20(UTC)
michelvr
Hi Tony,
First and foremost welcome to the world of Märklin model trains. Running Märklin model trains is like you’re in the land of Oz! Forget about two rail wiring and all the hassles back in Kansas! With that said, utilizing the PSX circuit breakers for a Märklin layout is not necessary as both the CS3 and or ECoS have short circuit protection built in. If you separate your layout to use boosters then you add more built in short circuit protection.
Two rail DCC wiring for shorts would warrant the PSX circuit protection but for three rail MFX/DCC not so as the possibilities of short circuits are minimized due to the configuration of Märklin track.
Offline trentschler
#7 Posted : 14 April 2021 21:31:14(UTC)
trentschler
Of course. I doubt mfx protocol would trip the PSX but to avoid any unknowns, I could just bypass the circuit breakers. My wiring is pretty modular so not a big deal. Or, I could just run DCC only but then miss out on the mfx features.
Offline michelvr
#8 Posted : 14 April 2021 21:41:30(UTC)
michelvr
If you are using the new Märklin locomotives you have the option to run them either MFX or DCC. Märklin has only been doing this for a few years now. But to get all the features of Märklin you need to use MFX. For example please read the link I provided for you below.
https://www.maerklin.de/...model-train-control/mfx/
thanks 2 users liked this useful post by michelvr
Offline Dirtboy
#9 Posted : 18 January 2026 17:34:13(UTC)
Dirtboy
I'm bringing this post back from the dead...
It is my understanding that with the CS3, if you have a short on you layout, the CS3 will cut power to the whole layout- including any boosters connected to the CS3.
I plan on having 2 boosters on my layout plus the CS3. I also plan on splitting my layout into 6 different power districts- 2 for each booster and 2 for the CS3. That will entail using 6 DCC Specialties PSXX1 circuit breakers; 1 for each district. That way, it there is a short in one district the whole layout won't come to a stop, just that one district.
My problem right now is programming the CVs in the PSXX1. It has a default DCC address of 2042 and I need to program CV49 to adjust the current limit of the breaker.
Does anyone know how to program DCC accessories with the CS3? Or perhaps with an ESU LokProgrammer? Those are the only tools I have available for DCC programming.
#10 Posted : 19 January 2026 17:09:17(UTC)
You should certainly be able to do it with a Lokprogrammer. It will do single CV changes on any DCC loco, and I would expect it to do accessories as well as I believe it can be used with things like the switchpilot to program them, so should understand accessory programming.
#11 Posted : 19 January 2026 19:23:35(UTC)
Originally Posted by: trentschler Go to Quoted Post
Hi All,
Thank you,
Tony
Hi Tony
Here a a Märklin CS3 user with a 100 VA power supply and my HO layout is connected directly without any circuit breaker.
As soon as an excessive current is detected, the CS3 starts chopping the power to limit the damage. What damage? Since 2012 I used a CS2 with this 100 VA power supply without any damage to wheels, rails,
What is needed is an easy way to identify in which part the short is detected.
This goes with dividing the layout into fully insulated CENTER STUD sections (no need to insulate the rails (called 0 by Märklin)
One wire powers one section (2 m long or so) so that by unplugging this wire allows to insulate the section.
With 5A of digital power, may layout has 27 locos all powered (no stop zones in front of signal but rather a digital control of speed using Rocrail.
Signals may possibly be the weak point in case of a short (they are given for 2 A but the power output of a CS3 is either 3A or 5A
DCC MFX, etc
MFX is much better when using Märklin: much easier to configure parameters than going through a zillion undocumented CVs
Anyway I always have used all 3 protocols active (including DCC) even though I was using amost exclusively MFX (and rarely MM2)
Now things have changed as I converted my Faller Car System into Viessmann CarMotion. Turnout modules are DCC and stops are IR beams so DCC is now used.
DCC, DC, AC etc
- the key two things are 2 rails or 3 rails and analog or digital and all the rest are very minor.
- so DC or DCC is confusing. DC often goes with 2 rails and DCC is only one of the possible digital protocols (Motorola, DCC, MFX, SX end a few others)
BTW here is my layout giving a flavour of what can be done with ONE CS3 and NO BOOSTERS
Offline Dirtboy
#12 Posted : 20 January 2026 23:31:51(UTC)
Dirtboy
Thanks! I gave it a go with my LokProgammer and it worked. I was able to set the current limits of the breakers. Factory setting was 2A; I set them all to 3A.
This page was generated in 0.638 seconds.
