Offline aussiephil
#1 Posted : 11 April 2021 05:47:42(UTC)
aussiephil
Hi guys
I bought a CS3 about two years ago and have not performed any of the available updates from Marklin.
My question is, do I need to download and install every update from the beginning or do I just download the latest update and it will incorporate every update that has come before it?
Many thanks in advance
Aussie Phil
thanks 1 user liked this useful post by aussiephil
#2 Posted : 11 April 2021 08:38:57(UTC)
Views messages in topic : 4,101
Phil, you continue telling it to perform updates until a red dot no longer appears in the update available box or window. Some take longer than others. Wait until the update successful prompt shows before moving on.
Offline aussiephil
#3 Posted : 11 April 2021 08:59:00(UTC)
aussiephil
Thanks so much for the advice - will do!
#4 Posted : 11 April 2021 11:41:53(UTC)
Generally the updates are cumulative - you only need to apply the current one.
When there is a specific need to be at a certain version before upgrading to a new version, the manufacturer will specify that in the update release notes. An example is when ESU updated the Ecos from v3 to v4 - you had to be at a certain v3.x level before you could go to v4.x - sometimes known as a 2 step upgrade.
Offline aussiephil
#5 Posted : 18 April 2021 00:31:40(UTC)
aussiephil
Thanks for the advice Bigdaddy - hope things are good across the ditch!
This page was generated in 0.372 seconds.
