Offline Rwill
#1 Posted : 04 April 2021 12:16:01(UTC)
Rwill
OK so its not April 1st so I maybe being “serious”. My layout is L shaped about 3m by 3m max – c track. Running around the outer perimeter is a double track circuit which is “controlled” by a block operation with circuit tracks to an S88 with three signals in one direction and four in the other. The signals are of mixed evolution, viessmann, hobby, latest M MFX – with some colour light and some semaphore. Nothing very scenic or prototypical and a complete mixture of loks, etc so nothing is sacred.
So, from the “control point” at the inside corner of the L I can see everything except just one pesky signal which no matter how and where I place it you cannot see the lighting aspect. My current solution (look away if you have a weak heart) is a hobby track/yard signal 74371 on the main line facing me on the wrong way/side of the track which even for me is hardly prototypical, but at least I can see the aspect.
Any better suggestions?
Offline blid
#2 Posted : 04 April 2021 12:53:33(UTC)
blid
Is it possible to place something white close to the signal? A wall of some sort. Try a bit of paper to check if the room is too bright to notice the color from the signal currently lighting up the paper.
This page was generated in 0.306 seconds.
