#1 Posted : 28 March 2021 22:09:15(UTC)
Ok, so I downloaded a lco image icom from ESU onto a usb stick, and installed it. The CS3 recognozed it, I edited the image on the list, and saved it. If I remove the stick, the image reverts to ?????? in the display. When I plug it back in, it reappears. A red update dot is also now showing in the systems box. CS3 is not and was not connected to the internet. Why is it saying there s an update? Can you only upload permamnent images from the web, and not a stick?
The only research I've found on how to is reffering to a CS2, not a 3.
Thank's in advance if anyone is able to assist!
Digital disaster Mike.Huh
#2 Posted : 29 March 2021 13:36:58(UTC)
it's ok people, I've emailed the Marklin Dudes. If they don't know, no one does except perhaps the firmware engineers.
#3 Posted : 29 March 2021 17:21:20(UTC)
Status update; Upon rebooting the cs3 today, the new loco icon has been retained! Yay! So the only question remaining is the red dot still in the system box. If one appears whenever you plug in a usb stick, can you delete the dot?
#4 Posted : 29 March 2021 18:50:28(UTC)
Better half just figured out the update pending was for the ms2. I clicked the cs3 icon in systems and it sent back the data. Red dot gone!
#5 Posted : 29 March 2021 21:30:38(UTC)
This is quite normal. What you did is to indicate the Icon name in your USB. If you remove the USB memory then for the CS3 it has disappeared hence the ???
You have to copy the icon file on your USB stick into the CS3 internal memory or to the SD memory if you installed one.
If I remember correctly you have to be in the loco edit mode to transfer the image into the CS3 memory
#6 Posted : 29 March 2021 22:18:43(UTC)
Oui, merci Jean! I did not know to copy the USB file or convert it to a png, but other half did. The edit locomotive window was open, and I clicked save and ok checkmark. Once the CS3 was started this morning the icon appeared for the locomotive.
This page was generated in 0.384 seconds.
