Offline avio
#1 Posted : 09 March 2021 16:09:06(UTC)
avio
Hello and good day to all
I have a couple of questions related to the new MFX Marklin signal that I will say works quite well in both my ‘continue’ and ‘alternate’ layout, but after having installed probably around 60 of those and replacing some of the old one, i will like to hear your opinion and suggestions on these two topics:
the first one is... as you know the more sophisticated signals comes with multiple color combinations, like 2 yellow and 2 green together or 2 white and red, and more, but when I go to program the ‘action sequence’ where switchers and signals can change positions and colors according to the right combination, I can do not much according to what I will like to do... (and here is my second question) like for example making a sequence like a few that I have seen in certain videos on youtube, like:
starting from red (standard position), then going to yellow green flashing with green for 2 sec, switching the turnout and then after another 2 seconds of flashing yellow green, the signals will finish the sequence on full green.
Do you know if managing a flashing in between 2 color schemes is possible? and if yes, can you please pass me some clues? many thanks in advance...
#2 Posted : 09 March 2021 16:33:52(UTC)
I've never seen such a sequence in real life in Germany.
AFAIK you can use routes on your controller to take the signal through several states.
Offline avio
#3 Posted : 09 March 2021 21:35:49(UTC)
avio
Hi Tom and thanks .. in fact you are certainly right.. in Germany you have seenna sequence like that.. mainly because I have never been to Germany and because in fact, I will like to use my own sequence.. if I manage to. In fact at the moment I am using routs to move signals and switcher together but presumably I have to practice more with this feature in my CS3 snd CS2, in order to create a sequence that can be extended in time, like 5 second all together in order to make the entire effect more dynamic and interesting.
The reason why I am asking here in this posts is because maybe someone before me has practice much more then me on this matter and has some approach method that can achieve a good final ling sequence in a easy way.. thanks
This page was generated in 0.355 seconds.
