Offline Rickmann
#1 Posted : 08 March 2021 11:20:47(UTC)
Rickmann
Hello my friends
Does anyone know the exact dimensions of the cogwheels Marklin 267310 and 267320? They are very very similar, but different.
If anyone could bring some light into this, I would be very thankful.
Best Regards and stay safe
Ricardo
Offline Zme
#2 Posted : 08 March 2021 23:28:10(UTC)
Zme
Hi. Don’t know what you need it for.
This is likely a close held secret.
Seriously, this could be proprietary information by Markin.
Maybe someone scanned each item and has this information. I have not seen it anywhere on the web.
Maybe someone can help you.
Best wishes.
Dwight
Offline Rickmann
#3 Posted : 09 March 2021 10:45:41(UTC)
Rickmann
Best wishes.
Dwight
Hello Dwight
I am having trouble with the last BR050, the 4 cogwheels came all mixed in a zip bag.
One of them is different from the others but they look like the exact same.
I need to buy a caliper (probably a digital one with very high definition).
Otherwise I am in trouble!! Of course I could try all the possible combinations, but I am afraid I can damage some of the parts.
Best regards and stay safe
Ricardo
#4 Posted : 09 March 2021 15:10:49(UTC)
Best wishes.
Dwight
Hello Dwight
Ricardo
Ok I looked it up in the Märklin online database
The exploded view is here
Z gauge BR 50 exploded view
You have indeed 3 small ones and one slightly bigger one
The exploded view shows where the bigger one is located (between 3rd and 4th coupled axle)
Simply count the teeth, there are not too many anyways.
Use a marker to put a ink dot on tooth "1" and count all around from there.
No caliper needed, just a magnifying glass...which you should have anyway if you have decided to take apart Z-gauge locos and attempt to reassemble! Wink
Good luck and tell us how you fared!
Jacques
Offline Rickmann
#5 Posted : 09 March 2021 15:23:17(UTC)
Rickmann
Best wishes.
Dwight
Hello Dwight
Ricardo
Jacques
Dear Jacques
The idea to count the teeth is genius !!!! As the IT techs say K.I.S.S. (Keep It Simple Stupid)!!!!!
If the locomotive wheels are all equal, the larger cog wheel must have more teeth (with the exact same dimension).
It never occurred to me. I was about to start complicating things.
Thank you so much Jacques (Vive la France).
Best Regards and Stay safe
Ricardo
Offline Zme
#6 Posted : 09 March 2021 17:12:45(UTC)
Zme
Hi Great, I understand your issue.
When you get everything figured out, I suggest just using the controller in short bursts and less than than full sustained power. I also try forward in short bursts and to the rear in short bursts. Just to reduce the possibility of damage.
I know you will make certain all other issues are within standards. Wheel timing, clean gears, motor lubricated etc.
Hopefully, it will work out for you.
Take good care.
Dwight
#7 Posted : 10 March 2021 00:04:07(UTC)
No problem.
Now , specifically to the reassembly, the largest one probably will have to be inserted last.
Re-assembling the transmission of Z gauge locos with side roads is a bit tricky, as you need to keep the axles properly synchronized/ quartered.
Patience will be your best ally.
Jacques
This page was generated in 0.380 seconds.
