Offline Rinke Blok
#1 Posted : 23 February 2021 09:12:11(UTC)
Rinke Blok
Goodmorning all,
just added a second MS2 to a layout for ease of running 2 locos. The tapping along to get to another loco is too cumbersome. Unless there is a trick I have not found about yet.
But when I operate the slave to take over a loco from the master, it says something along the lines of "not receiving confirmation from the master", just after I go into loco list.
Hence I cannot get the second one operational. Both are new.
I tried anything, from deleting the locos on the master, unplugging the master etc, cannot get it to work. Separate they work on different trackboxes individually, no problem.
The manual I will not even discuss as that is a joke, as usual figure it out for yourself and then the manual makes sense afterwards...
Anybody got any suggestions for me?Confused
thanks 1 user liked this useful post by Rinke Blok
#2 Posted : 23 February 2021 09:44:24(UTC)
Which firmware versions do your MS2s have? Are they both on the same level?
Master/Slave did not work when I started with firmware 1.3, but now with version 3.55 it works quite well.
Offline Rinke Blok
#3 Posted : 23 February 2021 15:07:47(UTC)
Rinke Blok
Thank you, going to check that.
This page was generated in 0.225 seconds.
