Offline Timnomads
#1 Posted : 08 February 2021 14:33:05(UTC)
Timnomads
Hi All
In my layout design I have along straight (6m) in C Track using 24360s: I would like to make it more interesting so have used the C track to K track converter and added some gentle curves for the 6m run using the K track flexible 900 mm pieces.
Does anybody have any experiences of running trains between C & K track, is this a good idea?
Tim
Online JohnjeanB
#2 Posted : 08 February 2021 15:16:40(UTC)
Hi Tim
There is no problem in mixing C track and K Track BUT:
* you need to use EITHER special rail joiners (between 100 and 80 rails
* OR to use normal 100 rail joiner and force then into a S Shape so that the top surface are aligned between C and K tracks
I have used Faller cork-bed under the flexible K rails with C track ballast from Noch
#3 Posted : 08 February 2021 15:22:42(UTC)
C track is code 90, so normal joiners could be a better choice than 100/80 joiners.
There still is the transition track from C track to K track that takes care of the difference in height with special rail joiners. If there is sufficient space, then these are a good option.
Offline PMPeter
#4 Posted : 08 February 2021 15:26:31(UTC)
PMPeter
I can only assume what Jean is getting at is if you want to connect K track directly to C track without using the adapter track.
My layout has several K to C track connections, but I always use the adapter track 24922 for the transition and I have never had a problem.
thanks 2 users liked this useful post by PMPeter
Offline Timnomads
#5 Posted : 08 February 2021 15:42:06(UTC)
Timnomads
thanks all
Offline perz
#6 Posted : 08 February 2021 19:05:54(UTC)
perz
We did direct C to K track connection on our company layout, because we needed K track to get enough clearance under a bridge. We used the normal K track joiners. It was a bit messy, but worked out well when it was done.
Per
This page was generated in 0.235 seconds.
