Offline PeFu
#1 Posted : 06 February 2021 17:34:16(UTC)
PeFu
Would anyone have a recommendation of 2-pole current conducting couplers for NEM pockets? I’ve found e.g. ESU, Piko and Viessmann offerings, but no recent review of them. I will not decouple the car sets very often, if any input.
Smile
Offline mvd71
#2 Posted : 06 February 2021 22:08:41(UTC)
I have used both the ESU and Viessmann units, of the two I intend to continue using the ESU ones. They can couple to a normal marklin close coupler or the Roco couplers without and problem, have two poles and a higher current rating than the Viessmann, so this enables more coaches to be powere from one pickup shoe etc....
#3 Posted : 07 February 2021 00:37:06(UTC)
Catalogue #s?
#4 Posted : 07 February 2021 06:24:05(UTC)
41001 ESU Conducting coupler for NEM pocket. 2 units package. Gauge H0, recommended retail price Euro 14.95, Modellbahn Lippe Euro 13.46, export price Euro 11.31
Offline mvd71
#5 Posted : 07 February 2021 07:23:18(UTC)
What he said, only I buy from Lokshop
Offline dominator
#6 Posted : 07 February 2021 10:23:40(UTC)
dominator
I'm curious here. I imagine you have to feed the power from these individually in each coach via bridge rectifiers, as you cant guarantee polarity. I have done he same, using single pole current conducting couplers, and made up my own earthing circuits via the wheels. Cost is far considerably less, especially when I converted my Marklin close couplers to current conducting ones. Shortly I will ad a thread here showing the result.
Dereck
Northland. NZ
#7 Posted : 07 February 2021 11:52:30(UTC)
The prices I've mentioned are only guidelines to give the person an idea what they are worth., you have to remember which wire is which so you don't mix them up and the best way to do this is with a multi meter, the benefit having a 2 pin electrical coupler, you don't need a pick up shoe which allows you to install a led strip with a resistor., if you intend to have separate lighting arrangements in your carriage it would be advisable to use a 4 pin electrical coupling whereas you can use Aux 1 for some of your interior lights and Aux 2 for toilet lights, entrance and some of the interior lights
#8 Posted : 07 February 2021 12:50:16(UTC)
I find it does not matter which wire you connect to another light bar.
This page was generated in 0.638 seconds.
