Offline Victor Almeida
#1 Posted : 04 February 2021 02:56:37(UTC)
Victor Almeida
My ice train long center cars rube on the vintage M turnouts semaphore. Is there something that can be done to modify and resolve this issue?
Any help would be greatly appreciated.
#2 Posted : 04 February 2021 03:16:20(UTC)
By semaphore, do you mean the throw lever that is used to change the turnout?
Offline PMPeter
#3 Posted : 04 February 2021 04:17:42(UTC)
PMPeter
By semaphore he might be referring to the lantern. I had that problem with some long Fleischmann cars rubbing on the lantern when they were going in the thrown direction (not straight through).
Offline mvd71
#4 Posted : 04 February 2021 04:24:17(UTC)
Märklin made m track turnouts with small lanterns when the introduced the 27cm coaches. Unless you want to replace the turnouts, your only option would be to remove the lantern assembly
#5 Posted : 04 February 2021 04:46:21(UTC)
My first thought was the turnouts with the larger lanterns are causing the problem. The only fix is to replace them with the newer turnouts with the smaller lanterns. I had to do this with mine when I had trouble with long coaches catching.
This page was generated in 0.246 seconds.
