Offline fynrfin
#1 Posted : 26 January 2021 22:46:11(UTC)
fynrfin
I always wanted to have a streetcar run back and forth on the streets of my town. I have found some nice ROCO models but they are only 2 rail DC - are there any I could run on three-rail? Or should I set up a separate small line in DC for the streetcar?
Steen Jorgensen
Planning a Northern European (DSB and DB) C-track layout with IB control.
thanks 1 user liked this useful post by fynrfin
Offline Mr. Ron
#2 Posted : 26 January 2021 23:41:46(UTC)
Mr. Ron
I think you would be better off with a separate DC setup. It won't connect with the 3-rail setup so there is not a problem. A trolley setup will run as a closed loop or point-to-point so you won't have any polarity problems plus a good variety of models available.
thanks 2 users liked this useful post by Mr. Ron
Offline IanC
#3 Posted : 27 January 2021 01:02:37(UTC)
IanC
Have a look at Rietze for modern trams / strassenbahn / streetcars.
IanC
thanks 2 users liked this useful post by IanC
Offline IanC
#4 Posted : 27 January 2021 12:20:08(UTC)
IanC
Also Tillig - Luna for pre-formed HO tramway sections
IanC
#5 Posted : 27 January 2021 18:03:25(UTC)
Navemo has some Street Car models, primarily Swiss in prototype, including some models for 3 rail AC.
One other possibility would be to use a DC catenary system for the trams
Offline PeFu
#6 Posted : 28 January 2021 07:36:30(UTC)
PeFu
Adding to this, if you go digital, you can use one controller (and power supply) both for the 2-rail trolley and your 3-rail Märklin layout.
Offline 60904
#7 Posted : 28 January 2021 15:18:41(UTC)
60904
Here is one, Roco. They offered it for DC and AC.
https://www.ebay.de/itm/...74f07:g:7IIAAOSwqkZgCxm~
Greetings
Martin
thanks 1 user liked this useful post by 60904
Offline 1borna
#8 Posted : 28 January 2021 21:31:00(UTC)
1borna
Croatia
My tram
UserPostedImageUserPostedImageUserPostedImageUserPostedImageUserPostedImageUserPostedImage
thanks 1 user liked this useful post by 1borna
Offline fynrfin
#9 Posted : 12 February 2021 19:37:27(UTC)
fynrfin
So all I need is two different kind of track, I can use the same power supply and controller?
Steen Jorgensen
This page was generated in 0.624 seconds.
