Offline Mr. Ron
#1 Posted : 15 January 2021 19:34:52(UTC)
Mr. Ron
I have finished building the framework for my layout. The size is approximately 12' x 13'. What would you recommend as the material to use for the top? I was thinking plywood, but what other materials might be better? Has anyone used 1" thick rigid foam insulation board? If plywood, what thickness?
#2 Posted : 15 January 2021 21:16:36(UTC)
1/2" plywood
#3 Posted : 15 January 2021 21:46:42(UTC)
Hi Ron
I think plywood is the best approach with 3/8 (10 mm)thickness in a frame structure
This is a good compromise for HO between weight, space between levels, cost.
The frame structure provides for solidity, access to multi-layer layout and noise reduction (foam or cork under the track is not needed with C track.
My structure is made of "beams" of 5/8 (15 mm) plywood mounted vertically (5" wide) in squares with removable feet with casters & brakes
Here is the look of it before landscaping
With landscaping there is no noise / resonance
Here it is with some landscaping
Offline Mr. Ron
#4 Posted : 16 January 2021 00:02:00(UTC)
Mr. Ron
Hi Ron
Thank you for sharing the video of you outstanding layout. It looks like it is running smoothly with lots of action. What DCC system are you using?
#5 Posted : 16 January 2021 05:10:27(UTC)
12mm MDF would be the only alternate I'd recommend to ply.
#6 Posted : 16 January 2021 12:22:41(UTC)
Hi Ron
Thanks Ron. The layout is using MFX and MM2. It operates from a CS2 (60215) a 60101 (100W Märklin power supply) and is driven by Rocrail. The system is Märklin 3 rails (detection by contact rails.
The wooden structure is so that there are 2 large modules forming a T and a small appendix. The Modules are 2.45m by 1.25 m and bolted together.
The structure can support the weight of a person.
Offline 1borna
#7 Posted : 17 January 2021 21:28:31(UTC)
1borna
Croatia
There are a lot of different types of plywood, some are heavy and have a solid surface into which it is difficult to screw something, especially small rail screws! Several years ago, I discovered an extremely light Ceiba plywood in which even the smallest screws can be easily screwed.
It is easy to cut and comes in various thicknesses and sizes. One plate 250 x 150 cm weighs only 10 kilograms!
The large layout of the Backo mini express was also made with the same material but slightly thicker. I used side and other load-bearing sides 10 mm thick and for larger surfaces and routes only 6 mm (with support).
thanks 4 users liked this useful post by 1borna
Bavarian Layout based on simple circular design! (Great layouts I have seen...)
by Marklineisenbahn 11/07/2022 16:58:14(UTC)
Layout Base(s). (General MRR)
by Jeremy Palmer 05/09/2009 03:54:12(UTC)
This page was generated in 0.510 seconds.
