Offline rhobson1968
#1 Posted : 09 January 2021 21:16:14(UTC)
rhobson1968
Hi, I haven't posted in a long time. I finally got my 7286 turntable on one of my layouts working correctly. However, the unlock function only works when the turntable is turning clockwise. If you go counterclockwise it won't unlock and stops at the next track. Any ideas?
Never quit building.
#2 Posted : 10 January 2021 01:35:32(UTC)
On the 7286 turntable, there is a feeler that is detecting a track position
Here is the motorization subassembly.
The feeler - when detecting a track position (real one or a possible one) - the latch switches off the motor and blocks it so that there is no "overshoot" (using a clutch)
If the voltage is too high or if the feeler guide is dry / dirty / needs a little lubrication then it can get stuck and the solenoid is not strong enough to disengage it
So 1 check with a lower voltage 12 to 14 VAC, otherwise remove the bridge and clean the motor unit.
Offline rhobson1968
#3 Posted : 10 January 2021 01:50:07(UTC)
rhobson1968
Thank you. what is the trick to remove the bridge?
Offline carlos.rivas16752
#4 Posted : 10 January 2021 17:08:59(UTC)
carlos.rivas16752
In Spanish but I guess the pictures may help:
http://www.trescarriles....otonda-marklin-7286.html
Carlos
This page was generated in 0.376 seconds.
