Offline Zme
#1 Posted : 06 January 2021 23:33:32(UTC)
Zme
Hi everybody
The latest version of Trainini is out and packed full of great z information. Find it here:
https://www.trainini.de/...Trainini_int_2020-12.pdf
The International Edition can always be located from their home page under downloads, select it at the top of the column on the right.
https://www.trainini.de/Downloads.html
Enjoy
Best wishes
Dwight
thanks 5 users liked this useful post by Zme
Offline scraigen
#2 Posted : 07 January 2021 16:12:43(UTC)
scraigen
Thanks, there's better content in there than in the Marklin Magazine!
Must build something
thanks 1 user liked this useful post by scraigen
Offline Vanvlak
#3 Posted : 07 January 2021 19:37:52(UTC)
Vanvlak
Malta
Thanks for the heads-up, the articles on the V80 are most interesting, in particular because of the variety of wagons the locomotive can pull.
thanks 1 user liked this useful post by Vanvlak
Offline Zme
#4 Posted : 09 January 2021 05:52:28(UTC)
Zme
You are right, that V80 looks like an excellent locomotive.
I also enjoy the articles about new product releases and to see the great layouts and maybe get some ideas.
Take good care.
Dwight
Offline Poor Skeleton
#5 Posted : 10 January 2021 20:53:18(UTC)
Poor Skeleton
Dwight
Doesn't it? I hope there's a non-insider version soon!
Chris
Offline parakiet
#6 Posted : 16 January 2021 14:53:38(UTC)
parakiet
There are already reports of faulty V80's
Hope mine is fine. Didn't have the chance to test it yet!
#7 Posted : 16 January 2021 16:18:37(UTC)
Poor Skeleton
Really? What sort of faults are people reporting?
Fingers crossed you have no trouble with yours!
All the best
Chris
Offline parakiet
#8 Posted : 17 January 2021 19:19:01(UTC)
parakiet
derailments and overheating!
#9 Posted : 17 January 2021 20:10:13(UTC)
Poor Skeleton
Derailments come as a surprise - provided I've replaced any plastic wheels with metal, that's something I almost never experience. The only exception, really, is if I run very long trains - by that I mean 13 or more 26m bogie coaches. I'm pretty sure they would be fine if my layout wasn't mostly on a 3% gradient, but must also be helped that I have nothing less than a 220mm radius curve.
I notice that V80 has a new bogie arrangement, and it's not clear from the exploded drawing how the pivot works, so I wonder if it moves less freely than the "traditional" arrangement and this is the cause of problems?
As for overheating, it sounds like this loco has a much greater gearing reduction that usual, so the motor will be running faster and perhaps this is the cause. I have noticed with the 88167 railbus set that it takes more voltage to get it started the longer it has been running - my interpretation being that the armature is warming up and causing the current to be lower as a result. I like the coreless motor (especially when it has a flywheel) for its smooth running and consistent speed, but it's not without its problems, in my opinion.
Chris
Offline parakiet
#10 Posted : 19 January 2021 09:59:13(UTC)
parakiet
And now more and more people are opening their V80.. and stumbling on bad or dodgy soldering. Ah Marklin.. (love/hate)²
Offline ajayrav
#11 Posted : 19 January 2021 19:22:01(UTC)
ajayrav
This is a beautiful locomotive! As others have pointed out, it is geared to run slow- and the top speed is low compared to other Marklin locomotives of its ilk. As a consequence, it is not as quiet as other small locomotives with the bell anchor motor such as the BR80 or the V36, or as smooth. That said, I haven't really run mine in yet.
The issue with mine is that it is noisier on curves, though it is certainly not enough of a problem to send it for service.
Ajay
Offline Zme
#12 Posted : 23 January 2021 02:01:31(UTC)
Zme
Hi everyone.
I was looking at the information on the V80 on Wikipedia and it stated the V 80 001 was the first unit of class V 80 introduced by the DB in 1953 with originally 800 hp
Perhaps as this z scale model was developed this was taken into consideration and the gearing adjusted appropriately. Still a nice locomotive, when the bugs get worked out.
Just a thought.
Best wishes
Dwight
Guest (6)
This page was generated in 0.309 seconds.
