Offline mymarklin99
#1 Posted : 22 November 2020 04:58:30(UTC)
mymarklin99
I have some older Marklin Gauge 1 Locos, crocs and E19's.....
Where do I find pickup shoes for these guys?
#2 Posted : 22 November 2020 06:54:21(UTC)
I don't think your Märklin locos are gauge 1 BigGrin
Only the MAXI range of gauge 1 had pickup shoes, and
there has never been a croc in the MAXI range Blink
Offline mymarklin99
#3 Posted : 22 November 2020 14:51:57(UTC)
mymarklin99
No, Im pretty sure they are Marklin Gauge 1 as I've been operating for 30 years.....and 100% not Maxi....
They are referred to as pickup shoes in the manual, but are not the same as Maxi which slide along the rails, meaning these pickup shoes supply power from behind the wheels by sliding against the back of the wheel. Pretty common actually so I assume you are not that familiar with locos 5517, 5758 etc as these have them as an examples.
Offline pa-pauls
#4 Posted : 22 November 2020 15:26:46(UTC)
pa-pauls
Spare parts list for 5517 is here :
https://static.maerklin....a49ee33b7d1434542203.pdf
and for 5758 the list is here : It is actually 5756 but I think the part you need is the same,,,
https://static.maerklin....3e6e3fbfea1434542476.pdf
Pål Paulsen
Offline mymarklin99
#5 Posted : 22 November 2020 15:31:12(UTC)
mymarklin99
Thanks, I have the part number, I was basically asking where would one find this part? Im having trouble locating it
Marklin part # 59 708 Schleiferfeder
Any help, greatly appreciated !!
#6 Posted : 22 November 2020 15:45:15(UTC)
OK, now I know what you mean; but I don't know where to find them Blushing
Per
P.S: I have a 5516 BigGrin
Offline pa-pauls
#7 Posted : 22 November 2020 18:47:10(UTC)
pa-pauls
Ok, I see, have you tried eBay ? The German eBay would be the best I think,,,
You can also try ETS (www.modelleisenbahn.com) big store outside Stuttgart, they have a lot of old trains
There is also many older dealers around that might have but to find the one store that does have it well that is not easy,,,
Maybe someone else have any idea ?
Pål Paulsen
#8 Posted : 22 November 2020 20:33:17(UTC)
https://www.modellbahn-p...-schleiferfeder-dq8.html
I don't know if it's the right part; but it has the right number Cool
This page was generated in 0.274 seconds.
