Offline 3864jk
#1 Posted : 15 November 2020 20:33:38(UTC)
3864jk
Some advice please: The Mfx decoder and the factory setting at code 60 do not seem to register on the mobile station. My other set is working OK on the Mobile system but the failed one has now been deleted from the controller and I cannot therefore reset it in Edit format
It showed up on the display with the flickering & Mfx sign arrows but did not settle into the working mode, although it had been working recently.
It will not register on any of my mobile systems nor on the IR controller at code 60.
At one point I detected a short warning symbol but it no longer produces this warning.
Many thanks in advance for any advice.
Problem solved!. It was a mechanical fault where the very weak axle wiper had become detached. Fortunately I was able to compare it with the working one and reattach and both now work. The wiper is split into a V shape and each side needs to be located individually against the axle support.
Hope this helps anyone in the future.
This page was generated in 0.328 seconds.
