Offline kfrankli
#1 Posted : 15 November 2020 14:52:28(UTC)
kfrankli
I've finally bit the bullet and started my first layout, using the Noch Cortina as the base. I'm trying to set it up to allow for 3 trains running automatically under signal control, 2 on the inner loop, 1 on the outer. I've used the official Noch Cortina trackplan:
Noch Trackplan
The track plan includes 3 universal relays total, 2 circuit tracks, and one block on the inner loop. Clearly the 2 circuit tracks are used to mainly control the crossing gates. Are these also supposed to control the one block to allow for 2 trains to run on the inner loop? Am I looking at the wrong track plan?
#2 Posted : 15 November 2020 15:23:25(UTC)
The 2 track circuits are one for the outer loop and the second one for the inner folded bone track. They also added a 3 stop sections (universal relays) for signals (too few IMO).
The track plan you show is of course the one on the Noch.de website.
It would be lovely to have this layout operate under digital but alas this is only possible after skillful conversion of selected Z gauge locos
I am not experienced in Z scale but in HO (Digital, PC-controlled) and N scales (an analog layout with home-made current feelers and smooth speed-control by a French System called Lybe now defunct).
Offline kfrankli
#3 Posted : 15 November 2020 16:25:30(UTC)
kfrankli
I'm thinking they don't show enough circuit tracks to control the signals given the 3 relays and only a single isolated block on the inner loop.
#4 Posted : 15 November 2020 16:48:49(UTC)
It is up to you but IMO, the inner loop must have minimum 3 signals for a block operation, assuming this is a one way loop
You must also IMO replace normal track sections with contact tracks (8589, 8529, 8539) located just after the signal / stop section, ideally 2 of them behind each signal (one to turn the signal red and the other one to turn the previous signal green).
Each relay or signal is connected to the common red and on the other side connected to each stop section. The track between the stop sections must be connected to the common red.
Offline kfrankli
#5 Posted : 19 November 2020 16:13:12(UTC)
kfrankli
Well I found a older Marklin HO wiring guide that I think is getting me to where I want to be. Now to develop a plan for my Noch Cortina!
https://www.marklinfan.n...cumenti/SignalManual.pdf
thanks 1 user liked this useful post by kfrankli
Offline husafreak
#6 Posted : 20 November 2020 16:31:44(UTC)
husafreak
Thanks for posting that link. I look forward to learning about signals, something I see a lot but don't really understand it in model railroad operation.
Offline veloboldie
#7 Posted : 24 November 2020 02:12:44(UTC)
veloboldie
You will need to find a copy of an old Marklin 0296 Track Layout Book to properly wire the signals for Cortina layout. If you are using the old 8939, the 8945 universal relay will work. However, it gets complicated if you use signals 89391-93; you will need to use the 7244 universal relays that are powered by the 16V AC transformer (for HO scale).
Guide to Z scale website is a good source for wiring: http://www.guidetozscale...ml/guide_to_z-scale.html
This page was generated in 0.289 seconds.
