Offline cgmolina61
#1 Posted : 30 October 2020 21:30:43(UTC)
cgmolina61
Argentina
Hi fellows
I'm using Train Controller with the CS3+ and 3 60882 feedback modules
The CS3+ works OK, it detect the 3 modules and display the block occupancy in the screen when a train pass over each block, but the Train Controller only detect the 1st 60882 module.
I wrote to the software developer and they answered me this:
The modules in the bus which is directly connected to the CS3+ must be specified with the device ID of the CS3 as Address.
<<< Important: Address refers to the CAN device ID, not to the decoder number in the bus.>>>
where is the CAN ID in the CS3+ menu?
I couldn't find it
thanks in advance
Carlos
Offline fosuna
#2 Posted : 31 October 2020 12:18:58(UTC)
fosuna
Hi Carlos,
You can see the UID of your CS3+, if you make a backup of your system.
Then, in the folder of your backup "work/config/dev/", there is a file named "devliste.cs2". This is a text file.
Inside, search for your CS3+ device (device.name=CS3-1), and in the ".uid" field you have in hexadecimal the UID of your CS3-GUI (Master). But in this file yoa also have the UID of the GFP3 inside of your CS3.
I hope this can help you. I do not know a better and faster way.
Greetings,
Francisco
Francisco Osuna
https://fosuna.net
thanks 1 user liked this useful post by fosuna
Offline cgmolina61
#3 Posted : 31 October 2020 17:53:38(UTC)
cgmolina61
Argentina
Hi Francisco
thanks for the data
I found the GFP3 UID Hex number, but I guess is not what they are asking me.
I can't introduce Hex numbers, when I convert it to decimal it's a huge one, didn't work.
I guess I need the number that the CS3+ gives to the second (or next) S88
The Train Controller ask for Address and Input. In the first S88 they are 1 and the pin where the detector is plug, 1 to 16.
For the 2nd I try with 2 and the pin number and didn't work, so they told me to enter in the ADDRESS the CAN ID of the S88.
thanks in advance for your help
Carlos (from Mex City)
Offline fosuna
#4 Posted : 31 October 2020 20:17:48(UTC)
fosuna
Originally Posted by: cgmolina61 Go to Quoted Post
Hi Francisco
thanks for the data
Hi Carlos,
I don´t know Train Controller. But if possible, try for the second and third S88s the same address as the first one (1, as I understand), and input 17-32 for the 16 pins of your second S88, and input 33-48 for the 16 pins of your third S88.
The 60882 feedback modules don't connect directly to the CAN Bus, so they can't have a CAN ID. Your three units must use the same CAN ID (that of your CS3 through they are connected). If Train Controller detects your first S88, the problem with your second and third S88 it is only with the identification of their pins, not with the detection of the S88s themselves. I do not know if I explain right.
Greetings,
Francisco
Francisco Osuna
https://fosuna.net
Offline cgmolina61
#5 Posted : 01 November 2020 03:35:23(UTC)
cgmolina61
Argentina
Hola Francisco
THANKS A LOT !!!!!!!
IT WORKED !!!!!!
ADDRESS : 1 and the pin # are 1 to 16 for the first one and 17 to 32 for the 2nd and so on ....
Thanks again I hope this helps other users
I'm installing all the LGB trains in a restaurant in MEX City with Train Controller, Train Bistro is the name of the restaurant. All work ok with the test in a CS2 but the CS3+ is a little different, you earn some beers !!!!!
Saludos y gracias
CM
thanks 1 user liked this useful post by cgmolina61
Offline fosuna
#6 Posted : 01 November 2020 18:31:43(UTC)
fosuna
Hola Francisco
IT WORKED !!!!!!
Saludos y gracias
CM
Hola Carlos,
Great that your problem is solved. Enjoy your trains!
Thanks for the beers! :-)))
Saludos,
Francisco
Francisco Osuna
https://fosuna.net
This page was generated in 0.268 seconds.
