Offline rhfil
#1 Posted : 22 October 2020 16:26:42(UTC)
rhfil
Is there any way to get around that Marklin does not allow advanced loco edit features on its Mfx locos? Seems a waste to offer a feature that is useless on all the new locos.
Online JohnjeanB
#2 Posted : 22 October 2020 16:53:32(UTC)
I don't know of any limitations on editing parameters on MFX locos except:
- sounds: they are locked on a factory-installed decoder
- the decoder parameters: brand, type, etc
All the rest can be edited on my old CS2 (minimum speed, maximum speed, acceleration, deceleration, speed curve, physical output modes (dimmer, Marslight, smoke, telex, etc), timer, active in one or both directions
These are only a few examples of the parameters available for you to changes (hundreds of them I think)
But I don't know what digital unit you are using
Offline applor
#3 Posted : 23 October 2020 01:51:54(UTC)
applor
You need to use the programming track
#4 Posted : 23 October 2020 10:20:53(UTC)
Not with mfx locos (but using the programming track avoids some potential problems).
Offline ocram63_uk
#5 Posted : 23 October 2020 17:33:50(UTC)
ocram63_uk
whether you put it on the programming track or on the running track doesn't change a thing. If you have a CS 1/2/3 maybe you can do more than with another piece of equipment. I have tried with an ESU Ecos and as long as the motor is not a s@@@y c-sine / SDS some changes are possibe using the graphic interface only, no direct CV programming, IMO. HTH
Online JohnjeanB
#6 Posted : 23 October 2020 19:00:16(UTC)
This is quite normal: if you purchase everywhere (non-Märklin) you don't benefit from a large part of the Märklin system. It is a choice.
SDS are exceptionally good. I have approx 12 SDS locos and I wish i had more.
#7 Posted : 24 October 2020 22:16:38(UTC)
Mfx locos?
What is a Mfx loco?
If you mean that the decoder in the loco may be able to operate using the mfx protocol, then this does not preclude the ability for the same decoders to also be programed via other protocols.
Maybe indicating which decoder is under consideration and which limitation has been encounter might assist.
Offline applor
#8 Posted : 24 October 2020 23:42:14(UTC)
applor
You can't do direct CV programming as MFX decoders have a 'MFX programming space' which works differently but you can still change all the parameters.
#9 Posted : 25 October 2020 02:23:43(UTC)
Again, what is a mfx decoder?
A decoder that may be able to communicate with the mfx protocol is also able to work with other protocols
#10 Posted : 25 October 2020 03:07:00(UTC)
If I understand this correctly, a loco I've purchases has a Zimo decoder installed and with the Zimo CV instruction pages I can change any CV with my Ecos., its just a matter of knowing how to which I haven't worked out yet.
Offline applor
#11 Posted : 25 October 2020 05:58:55(UTC)
applor
What I mean by that is MFX decoders that do not support DCC.
From my experience this means all previous Marklin and ESU decoders that were offered with either MM/DCC or MM/MFX protocols but not MFX (M4) AND DCC which was prior to 5th generation (ie. LS 3.0 M4 or LS 4.0 M4).
The 5th Generation ESU decoders (ie. standard loksound/lokpilot 5, not select) all support DCC and MFX (M4) and as such do allow direct CV changes including POM.
This is made very clear since when using the ESU lokprogrammer you cannot use the read/write CV function on MFX decoders that do not support DCC.
I believe this does not include adjustment of base CV's though such as loco address. Other settings such as accel/braking delays and top speed could possibly be adjusted direct by CV but I have not tested.
#12 Posted : 26 October 2020 11:40:36(UTC)
mfx programming works on main track and on programming track, it works with C-Sine motors and regular DC motors.
DCC programming on programming track does not work for many locos with C-Sine motor, but that's a different story. Problem is the motor driver board, not the decoder, not the motor.
This page was generated in 0.430 seconds.
