Offline geir
#1 Posted : 17 October 2020 18:31:31(UTC)
geir
Why does not cs3 read the S88 contacts.Could it be a faulty S88 Link? I have tested the power supply 66361,it gives 18v dc
Offline owidgie
#2 Posted : 18 October 2020 02:21:36(UTC)
owidgie
In short -
You don't have the CS3 looking at the correct port.
You need to set the contacts in your event script to Link-s88 if you are using an L88.
You need to set the Bus to "Direct"
You must make sure you have a reference ground connected.
Good Luck!
BigGrin
Rick
Offline geir
#3 Posted : 18 October 2020 14:23:41(UTC)
geir
All contacts/events worked last week.I have not made any upgrades/updating.But when looking at all the contacts(picture),there is no S88 AC moduloption ,only a Device-#2?.
How can that modul just dissapere?
I just made me a test switch on the S88 link ,Bus Direct and it worked.
Offline geir
#4 Posted : 18 October 2020 15:05:24(UTC)
geir
Could it be that something is meesed up in the system setting on Ling s88
Offline geir
#5 Posted : 18 October 2020 16:39:31(UTC)
geir
Everything is ok after change of ID change on system setting
Offline PerR
#6 Posted : 18 October 2020 19:23:43(UTC)
PerR
If you have one Link 88 (60883) and one S88 AC (60881) connected as shown at the picture then the Lenght of Bus 1 should be 1, and the length of Bus 2 and 3 should be 0 (zero).
Per
Offline geir
#7 Posted : 18 October 2020 21:29:42(UTC)
geir
I tryed to change the setting as you wrote and reboot ,but the system came up with the setting as above.And everything works.
Offline kgsjoqvist
#8 Posted : 18 October 2020 22:30:14(UTC)
kgsjoqvist
There is no harm in having the bus length a higher number than the actual number of devices. If it is lower the CS3 won`t recognize the last devices. The only problem if the number is too high is that the system will perhaps respond a little slower as it is trying to read input that doesn`t exist.
This page was generated in 0.523 seconds.
