3 Pages<123>
Offline Danlake
#51 Posted : 30 December 2017 06:07:07(UTC)
Danlake
Hi Minok,
Yes I have both a Marklin 60061 with EU plug and one with NZ plug.
Both gives similiar results.
And I tried various outlet socket in house - all similiar result.
I just tried another 12V DC adapter used for my telescope. Used plug in bathroom and used the water faucet as a ground point. I get 60V potential here....
Iam planning to purchase one of the outlet socket tester provided in links above and call an electrician out after New Year.
Brgds Lasse
#52 Posted : 30 December 2017 06:27:25(UTC)
Just on a lark what about neutral to water pipe AC voltage?
Offline Danlake
#53 Posted : 30 December 2017 07:30:03(UTC)
Danlake
Hi Minok,
Just tried that and result was 0V.
Brgds Lasse
Offline Danlake
#54 Posted : 30 December 2017 08:37:48(UTC)
Danlake
Been reading some more interesting reading:
https://electronics.stac...-ac-to-dc-power-adapters
https://superuser.com/qu...-adapter/1103702#1103702
So it seems that it’s normal to have seepage of electricity on DC adapter that has no ground pin?
All my test done so far has been done with DC adapters with only 2 pins including the Marklin 60061...
I just ran another test in my computer room.
DC adapter 30V with 2 pins = 110V to ground
DC adapter 12V with ground pins = 0V
My regulated DC power supply I used to compare test with the Marklin 60061 also has 3 pins and a metal chassis and maybe explains why I did not measure any significant voltage potential?
Now I wonder if everything is ok after all and I just have discovered something not many users are aware off?
But we are still back at the fundamental question then. Should the
Marklin power supply not have been designed with a ground pin? As depending on how you rotate the plug you could have up to 170V potential which will leak into the rails and give a lot of tingling...
Would appreciate if someone else could do a small test and see what potential they get from the rails or from the Marklin 60061 to a ground point in your train room? PleaseThumpUp
Brgds Lasse
Brgds Lasse
#55 Posted : 30 December 2017 09:07:46(UTC)
But we are still back at the fundamental question then. Should the Marklin power supply not have been designed with a ground pin?
AFAIK such a design would be illegal for toys in Germany.
Only very old Märklin transformers have a screw for a ground connection.
Theoretically there should be double insulation inside the power supply. Worries me to read that reversing the mains plug has such a huge impact on the leak voltage on the output side - apart from seeing any leak voltage on the output side at all.
#56 Posted : 30 December 2017 10:58:47(UTC)
Hi Dale,
Here is some measurements from the wall socket I used for testing:
Live and neutral = 240 V
Live and ground = 240 V
Neutral and ground = 0 V
And finally 0 V between ground and water pipe.
Above looks normal no?
Brgds Lasse
Yes, the above is as it should be.
One thing you could do, is to ground one of the output ( DC ) wires going from your 60061. This would make the maximum potential related to ground 19V DC.
Not solving the problem as in "why"; but protecting you from getting the electrical shocks.
Offline SteamNut
#57 Posted : 30 December 2017 11:51:08(UTC)
SteamNut
You have been a member since:: 11/05/2013(UTC)
Twice I saw something similar to your problem. Basically someone used ground as a neutral (the white wire back to the panel) which in one case caused an AC compressor to fail prematurely. The other time was for a outside sign when the ground as used as a neutral which caused someone a nasty shock.
#58 Posted : 30 December 2017 19:25:51(UTC)
Brgds Lasse
Yes that looks excellent and should rule out any high neutral of the house issue.
Offline tulit
#59 Posted : 31 December 2017 17:45:18(UTC)
tulit
FYI I had the same problem with the 60101. My difference is that I had it running through a 110->220 autotransformer. I concluded it must have been due to the non isolating design of the step up transformer. But it seems it maybe a inherient flaw in the design of the marklin SMPSs.
Saw the same problem with my dads 60101 + cs2 at his house too.
I stopped using it and moved to the 60065 which doesn’t exhibit this.
thanks 2 users liked this useful post by tulit
Offline Danlake
#60 Posted : 01 January 2018 07:43:45(UTC)
Danlake
Hi Per,
Once I rotate the EU plug in my NZ adapter the voltage potential drops from 170V to 60V and in that case you can’t feel anything when touching the rails.
I can live with this. However I will keep investigating this, also to rule out any issues with our house wiring.
But my suspicion is that there is a design flaw with Marklin switch mode powerpacks. As Tom mentioned it’s a worry if there can be so much seepage of voltage in the isolation part.
I will now contact my NZ dealer where I bought this power pack as well drop an email to Marklin digital club to see if they can do some testing.
Iam already in contact with Frank Mayer from Marklin Service and provided my a report of my test done, but it will probably be a while before I hear anything back.
But once again thanks for all the inputs and learned a lot of new stuff about electricity.
Brgds Lasse
#61 Posted : 01 January 2018 13:20:33(UTC)
I'm quite sure there's no issues with you house wiring.
Generally, grounding is always a good thing to do.
Make "your own ground" on an iron bar in the ground or something similar.
Don't use the ground wire in your power outlet; which could be catastrophic if someone later swaps the wires wrongly.
#62 Posted : 01 January 2018 20:14:23(UTC)
Rotating the Euro plug may result in 60V instead of the 170V you recorded, but I would be worried that that action might actually result in higher voltage being present in the centre rail than what the equipment can tolerate.
Have you checked studs to ground voltage?
#63 Posted : 01 January 2018 22:23:33(UTC)
Neither "studs to ground voltage" or "outer rails to ground voltage" is relevant for the equipment, as long as the voltage between studs and outer rails is around 19V.
Rotating the plug, resulting in 60V instead of 170V is just giving 60V +/- 19V instead of 170V +/- 19V.
To me it just shows that the 60061 is charging part of the output circuit, like a capacitor being charged, more so if the phase is on one of the 230V AC wires than the other.
Since it can be felt; but doesn't have enough power to light up a light bulb, I would just ground one of the output wires.
Of cause Märklin will have to come with a solution, because this is not acceptable.
Offline Danlake
#64 Posted : 05 May 2018 08:41:53(UTC)
Danlake
To finish off this post I will just summarise the latest info I got:
  • I had sent 2 detailed reports to Marklin Service and they have now confirmed they have done some testing. The power supply full fills all legal requirement and no deviations can be found
  • I also contacted my local dealer in NZ and he confirms it seems to a known design issue with switch mode power supply, but that the leakage current is still within specs.
  • I got my house wiring checked and all sockets are correct wired etc.
I did some research myself and it appears to be a well known dilemma for unearthed switch mode power packs. The main issue is that they need to limit EMI noise and by doing this they install Y-capacitor. It is these capacitor (by its design) that will leak current. There are international standard for different classes of power supplies (with medical grade equipment having the highest standard and unearthed power supplies the lowest). If you are interested in background read below article from stackexchange.com
Conclusion: in any switch mode power packs that has no earth pin there will always be some leakage current. The current can normally light up a small LED but not harmful to humans. I solved my problem by rotating the mains plug from the power supply 180 degrees. So if you feel electrical shocks from touching the rails - try and do that first.
Best Regards and safe railroading!
Lasse
Article from: https://electronics.stac...-capacitor-in-a-smps-do:
Switched mode power supplies use what is known as a "flyback converter" to provide voltage conversion and galvanic isolation. A core component of this converter is a high frequency transformer.
Practical transformers have some stray capacitance between primary and secondary windings. This capacitance interacts with the switching operation of the converter. If there is no other connection between input and output this will result in a high frequency voltage between the output and input.
This is really bad from an EMC perspective. The cables from the power brick are now essentially acting as an antenna transmitting the high frequency generated by the switching process.
To suppress the high frequency common mode is is necessary to put capacitors between the input and output side of the power supply with a capacitance substantially higher than the capacitance in the flyback transformer. This effectively shorts out the high frequency and prevents it escaping from the device.
When desinging a class 2 (unearthed) PSU we have no choice but to connect these capacitors to the input "live" and/or "neutral". Since most of the world doesn't enforce polarity on unearthed sockets we have to assume that either or both of the "live" and "neutral" terminals may be at a sinificant voltage relative to earth and we usually end up with a symmetrical design as a "least bad option". That is why if you measure the output of a class 2 PSU relative to mains earth with a high impedance meter you will usually see around half the mains voltage.
That means on a class 2 PSU we have a difficult tradeoff between safety and EMC. Making the capacitors bigger improves EMC but also results in higher "touch current" (the current that will flow through someone or something who touches the output of the PSU and mains earth). This tradeoff becomes more problematic as the PSU gets bigger (and hence the stray capacitance in the transformer gets bigger).
On a class 1 (earthed) PSU we can use the mains earth as a barrier between input and output either by connecting the output to mains earth (as is common in desktop PC PSUs) or by using two capacitors, one from the output to mains earth and one from mains earth to the input (this is what most laptop power bricks do). This avoids the touch current problem while still providing a high frequency path to control EMC.
Short circuit failure of these capacitors would be very bad. In a class 1 PSU failure of the capacitor between the mains supply and mains earth would mean a short to earth, (equivalent to a failure of "basic" insulation). This is bad but if the earthing system is functional it shouldn't be a major direct hazard to users. In a class 2 PSU a failure of the capacitor is much worse, it would mean a direct and serious safety hazard to the user (equivilent to a failure or "double" or "reinforced" insulation). To prevent hazards to the user the capacitors must be designed so that short circuit failure is very unlikely.
So special capacitors are used for this purpose. These capacitors are known as "Y capacitors" (X capacitors on the other hand are used between mains live and mains neutral). There are two main subtypes of "Y capacitor", "Y1" and "Y2" (with Y1 being the higher rated type). In general Y1 capacitors are used in class 2 equipment while Y2 capacitors are used in class 1 equipment.
So does that capacitor between the primary and secondary sides of the SMPS mean that the output is not isolated? I've seen lab supplies that can be connected in series to make double the voltage. How do they do that if it isn't isolated?
Some power supplies have their outputs hard-connected to earth. Obviously you can't take a pair of power supplies that have the same output terminal hard-connected to earth and put them in series.
Other power supplies only have capactive coupling from the output to either the input or to mains earth. These can be connected in series since capacitors block DC.
thanks 13 users liked this useful post by Danlake
#65 Posted : 06 May 2018 12:10:48(UTC)
Not just switch mode power packs, my story back in post 37 covers exactly the same thing, capacitive coupling from the primary to the secondary side, in that case the primary was the heating element of the electric blanket, and the 'secondary' was the person in the bed.
Offline dominator
#66 Posted : 07 May 2018 07:21:09(UTC)
dominator
He's the man eh. Well researched Lasse
Dereck
Northland. NZ
Offline Danlake
#67 Posted : 23 May 2019 01:06:25(UTC)
Danlake
HI all,
Here we go again. Now also excessive "touch current" observed with newer type power supplies to MS2.
This issue only became apparent for me sometimes after 2017 when I had to replace by power supplies to my old CS2. And last year I bought a brand new MS2 (black) with a power supply from 06/17.
I wonder if Steger (the manufacture for Marklin of their power supplies) have changed their design and gone overboard in their pursue to limit potential EMC (higher Y capacitors will limit EMC but also increase "touch current).
See below photos for test results:
While trying to reset an old MM decoder I used my MS2 on the test bench and got a really nasty shock when accidental touching the rails (was standing bare feet in my garage on concrete floor). I then took my multi meter and measured a voltage potential from outer rail through my body to ground of 207V. Fortunately unable to measure any current (miliamps).
I then rotated the EU plug 180 degree in my NZ power plug adaptor and performed a new measurement. Now hardly any voltage.
Conclusion; as stated in previous post if you feel a "touch current" from the rails try rotating the power plug (for your switched mode power packs).
I have previously been in contact with Marklin with no avail and wonder if I should try and get hold of Steger directly? The other options would be to try and contact the EU regulatory body who approves these class II power supplies. Knowing Steger is supplying the space industry with components and Marklin previously have been obsessed with EMC/noise I wonder if they have compromised on safety here in pursue of minimising EMC...
Best Regards and safe modelling
Lasse
thanks 3 users liked this useful post by Danlake
Offline tiono
#68 Posted : 23 May 2019 02:51:18(UTC)
tiono
HI all,
yes, I also got the same electrical shock, which disappeared after I rotated the power plug.
My solution: use a three-pin power plug adapter, so that it will always in the correct position. (This solution will only work if the home power socket is non rotatable three-prong, in my case; it is UK type G)
thanks 1 user liked this useful post by tiono
#69 Posted : 23 May 2019 11:07:57(UTC)
Lasse
This supply will pass CE certification, which is a self certification system. However the manufacturer has to have a significant file of information on what they have done, materials used, etc. It does not need to go out to any 'regulatory body' for approval.
Steger may be supplying the space industry with components (but I work in the space industry and haven't come across them as a source) but these power supplies will certainly NOT use any space qualified components, they would simply be too expensive.
The sort of shock that you have received can also be achieved from an electric blanket if you had the same 'bare feet' connection with earth. There has been quite a discussion on this forum previously about this.
I can assure you they haven't compromised on safety, the fact that you couldn't measure any current shows that.
Offline Danlake
#70 Posted : 23 May 2019 13:49:28(UTC)
Danlake
Hi Alan,
I think you are right - not the space industry but the aviation industry. My mistake. On their website they claim to supply transformers to both Boeing and Airbus.
https://www.stegertrafo.de/en/company.html
Anyway my point regarding safety is more towards Marklin clearly marketing their products towards children and use of carpet bahns etc. So even though the current is almost nil you can still get a nasty shockScared
There has been numerous media reports about laptop manufactures getting in hot water when users complains about not being able to rest their hand on a metal chassis laptop while its charging...
I am no electronics expert but as a common user it also makes sense to ask; what would happened if those Y capacitors fails?
From this website there is some interesting reading but the application of Y capacitors may not be the same as within our switched mode power packs:
http://powerblog.vicorpo...6/what-are-y-capacitors/
When does capacitor reliability become critical to safety?
Line filter capacitors are classified either as X-capacitors or Y-capacitors. X-capacitors are connected between line and neutral, to protect against differential mode interference. Their failure does not create conditions for dangerous electric shock, although it can create a fire risk. However Y-capacitors are designed to filter out common-mode noise, and are connected between line and chassis; if they short-circuit, they create a risk of shock to the user.
Best Regards
Lasse
#71 Posted : 23 May 2019 14:33:07(UTC)
Best Regards
Lasse
X and Y capacitors are made from materials that will not fail short circuit. They use a construction known as 'self healing' on non-ceramic versions so that if the insulation does punch through they will isolate that spot and become a capacitor again, or technology that causes it to go open circuit on ceramic versions. See this link for a broader discussion on them than the link you posted.
Offline dominator
#72 Posted : 24 May 2019 01:02:41(UTC)
dominator
Interesting comments. I must admit, I haven't had the problem yet but I dont think I have touched the tracks to cause it or maybe because I have carpet on the floor???
Lasse, time to put on your "Maori safety boots"maybe..
BTW, my mate still raves about your magnificent railway. Maybe its time for another fix. [ He has seen John Haymans railway as well. ]
Dereck
Northland. NZ
Offline Danlake
#73 Posted : 24 May 2019 04:38:17(UTC)
Danlake
Hi Derek,
You guys are always welcome and you could bring your MS2 if we want to try and update them via my CS3...
Done a bit more scenery on the layout and could also show off my winter displayBigGrin
I think the reason you haven’t had any shock is because your power supplies are perhaps older than 2017?
Best Regards
Lasse
Offline Danlake
#74 Posted : 09 October 2019 10:56:01(UTC)
Danlake
So it looks like Marklin has finally acknowledge the issue discussed in this thread. I did have various correspondence with Frank Mayer when I first reported this issue to them and even though the safety notice appears also to be a legal disclaimer, at least they acknowledge there can be leak current, and it can be uncomfortable, it won’t be harmful.
So thank you Marklin for taking it seriously and listening to your customers (not meant in irony) ThumpUp
See below link for full documentation or read extract here:
https://www.maerklin.de/...rische_Sicherheit_en.pdf
Today's switching power supplies, which are necessary for the conversion of the mains voltage into a low voltage for the supply of the control system and loads on a model railway, require an interference suppression circuit to comply with the EMC regulations. However, this can lead to a leakage current flowing between the potential on a rail and a protective conductor of your domestic installation. If, for example, you connect the live rails with one hand and the protective conductor of the house installation with the other hand (e.g. metal back panels of computers or power tools can have this connection) or to an earthed object (e.g. a radiator), you close the circuit for this leakage current.
All Märklin supply units have been tested to ensure that the limit of 0.5 mA for such a leakage current, which is listed as safe and in many standards, is not exceeded. Sensitive people can, however, already feel such a current of this magnitude under certain circumstances as a tingling current flow at least in parts of the body.
What are the dangers of electric shock?
A current flow only occurs when the supply and return conductors of an electrical supply source are connected to each other via a conductive material. The human body is capable of doing just that. One then speaks of an electric shock, which the affected person suffers.
The damage that can occur depends on many factors:
 The level of the applied voltage
 The type of current and its frequency
 How much electricity flows
 The exposure time
 The path through the body
 Possibly existing technical components such as cardiac pacemakers
Voltages above 60 volts can cause life-threatening injuries in the event of an electric shock. The supply voltage of the model railway is therefore limited to a maximum of 24 V. No loads with a higher supply voltage may be used on the model railway.
The amount of current at which a current flow is perceived is between 0.01 mA and 4 mA, depending on the circumstances. Currents up to 0.5 mA are classified as harmless. Currents up to approx. 5 mA do not lead to injuries in a healthy adult, but they do mean an unpleasant perception of the current flow. If you comply with the requirements of this document, you can be sure that, according to the current state of knowledge, there is no danger of dangerous leakage currents in your system.
Best Regards
Lasse
thanks 5 users liked this useful post by Danlake
#75 Posted : 09 October 2019 12:55:54(UTC)
This looks like it could be an english translation of a german document that has been around for a while.
Offline oranda
#76 Posted : 20 September 2020 10:56:04(UTC)
oranda
This is a fascinating post.
It does however appear to pose a health and safety issue, which is somewhat down played in the safety pdf. Who would know this unless they were looking for the document?
As this group of hobbyist who probably fall in the category, more likely to have a pacemaker, I wonder why more prominence is not given to this issue in the sales of these devices.
Or am I being paranoid?
Offline Danlake
#77 Posted : 22 September 2020 10:35:32(UTC)
Danlake
I thought I was being paranoid when I started this post, but felt it was somewhat justified when Marklin finally put forward some safety warning.
I have a young daughter and lots of her friends comes and play with the trains. I was genuine concerned that they wold get quite a fright if touching the rails, standing barefeet in our garage.
Personally for me it felt like a real uncomfortable shock, much more than what you would have been exposed to in physics class in the old days...
I still think it’s a design/cost issue that Marklin has opted for and could be mitigated either by supplying the switch mode power pack with earth plug or design them to a higher class standard (similar to medical grade units).
A standard consumer PC with metal cabinet now comes with earth plugs, a model train layout scattered with exposed metal rails, marketed for children, can be powered with a cheaper option that comes with warnings of potential small electrical shocksBlink
Best Regards
Lasse
#78 Posted : 22 September 2020 11:55:33(UTC)
Earth plugs are not allowed for toy power supplies.
But a different design should be possible.
#79 Posted : 22 September 2020 12:12:58(UTC)
Go piss on a cow-fence, and you will know the different between a Märklin "electrical shock" and a REAL electrical shock! BigGrin
PS: The real danger of the M. electrical shock is for the fine electronics that are used all around the layout today... (IMHO)
#80 Posted : 22 September 2020 13:38:29(UTC)
Don't worry about the cow-fence Henrik, above all don't pee on your third rail pukos !! OhMyGod :
https://newsfeed.time.co...g-on-subways-third-rail/
Scared
Offline morsing
#81 Posted : 24 September 2020 11:26:49(UTC)
morsing
I have just measured my outer rails to ground block voltage and get 156V. I only started feeling this brushing against the rails a couple a months ago, so I don't think mine has done it all along.
Henrik
Marklin C-track + CS3+
#82 Posted : 24 September 2020 11:34:35(UTC)
morsing, im not saying that you are wrong, but are you sure that is true rms?
Offline Danlake
#83 Posted : 24 September 2020 11:35:33(UTC)
Danlake
Hi Henrik,
Try and rotate your main power plug 180 degrees (the plug that powers your switch mode power pack) and then do a new measurement.
Best Regards
Lasse
Offline morsing
#84 Posted : 24 September 2020 11:48:23(UTC)
morsing
How can I tell?
Offline morsing
#85 Posted : 24 September 2020 11:49:58(UTC)
morsing
Hi Henrik,
Best Regards
Lasse
I'm in the UK, no-can-do :-)
#86 Posted : 24 September 2020 12:10:50(UTC)
How can I tell?
You need to use a tester that contains the necessary electronics, in order to suppress readings of "noise".
You can get all kinds of "high" voltage readings from floating signals. But once it has to actually carry a current, the voltage collapses... (as in "it isnt real")
Usually your meter will say "True RMS" on some label, or in the instructions.
Cheap hobby-meters from the DIY shops are notoriously known for lacking this.
Try with a good-quality FLUKE-meter...
PS: floating, noise and rms are different things. I´m not an electrician, so dont take my word for it! ;-)
Offline morsing
#87 Posted : 24 September 2020 12:16:34(UTC)
morsing
It's certainly wasn't cheap - not when you're a hobbyist anyway... Laugh
thanks 1 user liked this useful post by morsing
#88 Posted : 24 September 2020 21:54:43(UTC)
Henrik
Yeah, but that requires a high impedance meter to achieve that voltage. If you were to connect the same points with a resistor of anywhere between 100k and 1M it will drop dramatically.
I would regard this as normal for a double insulated unearthed secondary. Brushing the back of your hand against the rail will give a gentle tingle but a firm connection will not give you any shock, even if you also contact an earth point.
Offline Danlake
#89 Posted : 25 September 2020 09:12:15(UTC)
Danlake
Hi Henrik,
Best Regards
Lasse
Same in New Zealand. What I did was to open the plug and swop the wires (which is similar to what would happened if you had a EU plug). But if you don’t have any discomfort you might as well leave it.
However on my layout, regardless of what other users say here, I got nasty shocks to the state where I could not keep my finger on the rail pressed down. I never manage to measure any miliamps so the current is very small.
Best Regards
Lasse
Offline morsing
#90 Posted : 25 September 2020 09:18:50(UTC)
morsing
It is un-comfortable, it's actually painful accidentally brushing my arm against the rails. When touching it permanently, I can still feel tingling.
I can re-wire the plug, but would probably end up in trouble doing it :-D The authorities have some strange ideas here...
Henrik
Offline Danlake
#91 Posted : 25 September 2020 10:23:42(UTC)
Danlake
Hi Henrik,
That’s how I felt it as well. When I first noticed it was when I had to get a derailed wagon back on the track in my shadow yard I had my whole arm stretched and the hair just brushed the railScared
I bought my switch mode power packs from a German dealer and fitted with the Schuko plugs. I removed the plug and fitted a NZ plug (which you are allowed to do yourself as a home owner). Interesting part is that when I wired the plug according to the conventional colour standard with blue wire being neutral I had the worst outcome. I then swopped the wires and no issues.
Just reading a bit more about polarity and Iam by no mean an expert in this field so I thought I include below text from a UK dealer:
Should I worry about polarity?
The UK electrical system is polarised. The earth pin on 13A plugs is at the top, they can only be inserted one way and the live is always wired to the right hole (as you face a socket). As the live is always connected one way, appliances are wired with this in mind. For example, a switch may only turn on/off the live wire. If the appliance is used in Europe and the polarity is reversed (e.g. the live is connected to neutral, and neutral to live) such as would occur when using a Schuko socket which can be inserted either way round, the switch now only turns on/off the neutral. The appliance would appear off, but it is actually still live.
This is particularly important when connecting caravans, motor homes or boats as they will often have circuit breakers that isolate only the live. If the polarity is reversed and a fault occurs, they will cut off the neutral. This leaves the faulty appliance still live, which could prove fatal, particularly if there was also an earth fault e.g. the metal of a caravan would remain live and electrocute anyone who touched it.
In the UK some EV chargers expect the power to be configured in that way, and will not operate if the live and neutral are connected the other way around (the polarity is reversed).
Best Regards
Lasse
#92 Posted : 25 September 2020 10:51:45(UTC)
Go to "Poundland" Cool
They have "1 to 3" very short extensions; on the male plug of that you can swap the wires and make a test BigGrin
Just don't tell the authorities about it LOL
Offline T D Sutton
#93 Posted : 11 October 2022 10:04:04(UTC)
T D Sutton
This is an old thread, but from reading through it tonight it describes exactly what I have been chasing on a friends large layout with 5 or 6 boosters along with the CS3 doing it's bit. The owner has complained for several years of getting shocks off the running rails, but we were not able to prove it until today when I pondered the EMS filters inside the powerpacks being the culprit. I was measuring around 115 V+ AC at minimal current between the house earth and the running rails. I removed all but one powersupply, and we measured around 40 V AC. We then measured a similar voltage when each of the powersupplies was connected one by one, and climbed up in steps when each powersupply was later added to the setup until with all connected the 115 V+ AC reappeared.
Grounding the running rails to mains earth did the trick, and as expected :-) the voltage dissappeared. After pondering the problem I inserted a 470 mfd 16 V capacitor in series with the earth wire and "LO-and-Behold" the rogue voltage on the running rail was non-existant and the layout appears to be operating normally. The 470 Mfd cap was the only capacitor in my toolbox at the time, and I plan to replace it with one of a much highter voltage rating in the near future, and possibly somewhat smaller capacity. My thought would be to try around 0.47 Mfd 400 V rating which is what one sees on switchmode powersupplies.
More "digging" may be required, and I would love to see the schematic of one of those new grey powersupplies to see how they have arranged the suppression capacitors indide the beast!
Terry
thanks 3 users liked this useful post by T D Sutton
#94 Posted : 11 October 2022 12:34:43(UTC)
I don't think grounding is the issue. In Europe, our 60061 60101 are fully isolated (no ground return) and the checks are very very stricts on those things (in this case the double insulation requirement) and companies can go bankrupt as a consequence of breaking the rules.
However, I have observed that with a dry hand and thick skin, I don't feel anything when touching the digital rails BUT with moist or wet hands and a soft thin skin (like the top of the hand, I can feel very unpleasant shocks. Not dangerous but you want to avoid it.
After all there were rules to limit voltage for toys down to 20 V.
Offline Copenhagen
#95 Posted : 11 October 2022 16:09:25(UTC)
Copenhagen
Depending on what slippers I wear I can get some nasty shocks from static electricity when the trains are running and I move about my layout and touch stuff. So I either have to take one of the slippers of or remember to use the right footwear.
#96 Posted : 11 October 2022 18:51:37(UTC)
Is there a solution for this issue by using a third party power supply/adapter that does not use switching technology?
#97 Posted : 11 October 2022 22:16:52(UTC)
It is possible to get a similar tingle from a powered on electric blanket. It depends where the other end of your body is when putting your hand near the blanket.
I'll have to open my two power supplies to see how the EMI filter is wired.
Offline T D Sutton
#98 Posted : 12 October 2022 05:04:40(UTC)
T D Sutton
I would love to see what you find inside the power supplies, in particular how they have configured the drain capacitors. I attempted to open one of my friends supplies, but without doing some serious surgery, I gave up. If it had been my own I would have persevered :-)
#99 Posted : 12 October 2022 14:26:13(UTC)
Moisture on your fingers can also make you more sensitive.
#100 Posted : 12 October 2022 22:04:07(UTC)
From https://www.marklin-users.net/fo...osts/t39302-Repairing-a-
The only way to get inside the case.....
Well, that and the use of an oscillating tool for the ends of the case
View from top
Circuit board removed from case
Rear side of circuit board
3 Pages<123>
This page was generated in 1.144 seconds.
