Offline MikeR
#1 Posted : 17 September 2020 18:53:57(UTC)
MikeR
Good day everyone. I moved to the US about 3 years ago and am finally getting back into model railroading. I have agreed with my wife that I will build and run a 1-gauge layout on our front porch around a Christmas tree. The layout will be a loop with a passing siding. I have 2 MAXI locos with DELTA decoders which will run in opposite directions around the loop. I will be using my CS2 with 72441 braking sections. I understand that the slowing down won't work with the DELTA decoders but the stop section will.
To improve the experience for my grandchildren I am seriously considering upgrading the decoders in the 2 locos to Loksound 5 decoders and fitting smokers in both locos. The maximum motor current of the normal ESU Loksound decoders is 1.5Amps while there is a 5Amp XL version that is available but at twice the price. I would like to fit the cheaper/normal decoders and was wondering whether anyone had any experience of the need for the XL decoders in a MAXI loco? One of the MAXI locos came in a starter set with a 32VA analog transformer. This is quite close to 1.5Amps power supply and would be used for the motor and incandescent lights. Hence I am leaning towards the cheaper decoder.
I also have a 55032 starter set with a class 80 locomotive and a 32VA transformer. Again does anyone have any experience installing a standard decoder in a 1-gauge loco of this size?
Member of ETE
#2 Posted : 17 September 2020 19:19:25(UTC)
For very small locos, running with only very few wagons, you can use the H0-decoder; but I wouldn't do it Cool
I would use the Loksound 5 L, made for 0-scale, they are cheaper and smaller than the XL-model Blink
http://www.esu.eu/en/pro...nd-5-l-loksound-5-l-dcc/
I have not done it myself; but I've seen several locos converted with the 5 L, including a BR80 BigGrin
Offline MikeR
#3 Posted : 17 September 2020 21:10:12(UTC)
MikeR
Hi Per
Thanks very much. The L decoder has a maximum motor current of 3Amps. Just what I need! I had not noticed this decoder and it will be a good match to the MAXI locos.
Member of ETE
thanks 1 user liked this useful post by MikeR
This page was generated in 0.320 seconds.
