Offline Ross
#1 Posted : 07 September 2020 02:06:58(UTC)
Ross
Hi All,
When was the last time you checked your stored locomotives?
I noticed the foam in the box for the 37990 Big Boy had a few holes in it and on closer inspection it just disintegrated when I tried to remove it from the wooden box.
Ross
thanks 4 users liked this useful post by Ross
Offline ixldoc
#2 Posted : 07 September 2020 02:50:41(UTC)
ixldoc
Hi Ross,
I have a friend with one of these stored in it's box.I will warn him to check it immediately.
Howard.
Offline Ross
#3 Posted : 07 September 2020 04:31:52(UTC)
Ross
Hi Howard,
I wonder how many people have had this problem.
I won't replace it with something else but just leave a nice air gap around the loco.
Originally Posted by: ixldoc Go to Quoted Post
Hi Ross,
Howard.
Ross
#4 Posted : 07 September 2020 06:56:29(UTC)
Hi All,
Hello Ross,
It seems “foam” has a propensity to disintegrate over the years (the first part of this old post is the relevant bit) :
https://www.marklin-user...rack-problems#post515769
PJ
Offline Ross
#5 Posted : 07 September 2020 10:02:58(UTC)
Ross
Hi PJ,
Yes it would seem that foam is a problem.
Ross
#6 Posted : 07 September 2020 10:35:25(UTC)
I never leave locos in boxes. I just run them on a regular basis. If for some reason you can not have the use of a layout then a display cabinet should be ok plus you can actually see them.
Offline Michael4
#7 Posted : 07 September 2020 11:01:59(UTC)
Michael4
It is the same with light seals on the doors of old cameras. Beware, if it becomes sticky when it disintegrates it can be difficult to remove.
#8 Posted : 07 September 2020 11:55:11(UTC)
I would like to point out the import of the temperature and humidity of the place those boxes are stored.
#9 Posted : 07 September 2020 13:28:58(UTC)
My 4013 Big Boy spent much of its time in its box in Paris mild climate
Its box is excellent but the black velvet foam is less elastic than before.
I assume (hope) that it does not deteriorate the loco which -so far- looks brand new
Offline dickinsonj
#10 Posted : 07 September 2020 14:05:49(UTC)
The foam for my 4013 is still intact but it feels different - almost damp to the touch. I assume that is the beginning of the end for it and I should probably just remove it before it ends up like the mess Ross has.
#11 Posted : 07 September 2020 14:28:18(UTC)
Hi Howard,
I would be wary of doing that, I think the foam holds the loco down when the box is closed. If you don't have the foam and turn the box upside down the loco will fall on its roof. You need something at the ends of the board the loco is bolted to to hold the board down if turned over.
Offline Ross
#12 Posted : 08 September 2020 00:08:53(UTC)
Ross
Hi Alan,
The lid has wood at both ends that extends past the box edge so when the box is closed it holds the loco mounting plate in a firm position.
I have done the shake test and it passed.
Hi Howard,
Ross
thanks 2 users liked this useful post by Ross
Offline klarinettmeister
#13 Posted : 08 September 2020 11:43:24(UTC)
klarinettmeister
I've checked all my BBs and I´ve also noted that the foam inserts changes over time.
The 37990 is a little bit sticky so I´ve put some extra plastic between the foam and the wood and also some extra plastic bags on top of the loco. I´ve done it to 37991 and 37993.
thanks 1 user liked this useful post by klarinettmeister
#14 Posted : 08 September 2020 18:55:11(UTC)
Hi Alan,
Ah, OK, I went back to look at your photo, and yes, can see the pieces on closer inspection.
Offline Ross
#15 Posted : 08 September 2020 23:08:27(UTC)
Ross
Hi David,
Keep checking your locos as when I tried to remove it to find out how bad the foam was I found it had glued to the box lid in places and felt like tar or very sticky oil and was extremely difficult to remove.
Ross
Offline Dave Banks
#16 Posted : 09 September 2020 00:20:48(UTC)
Dave Banks
I pulled my BB out of storage today & found the issue you have mentioned. I don't want it to come to a situation like Ross has found himself with. I hasn't got to the stage of being a huge issue but I am taking steps to fix it. I will trundle down to the local Foam shop & ask him to cut me some new foam that is not going to "bio-degrade" if I can use that term & not let it get to the stage of becoming a sticky mess. I will keep you updated on this if you like with a picture of the pending outcome.
Dave...
D.A.Banks
#17 Posted : 09 September 2020 00:30:05(UTC)
klarinettmeister
Hi Ross!
I noted the foam in 37990 and 37993 had started getting sticky already. I'll probably remove them. It's a shame they don't last that long. It seems there are no perfect boxing solutions really.
It's really good you raise the problem here. It's probably gonna be the same problem with the Challenger's...
/David
Hi David,
#18 Posted : 09 September 2020 05:19:38(UTC)
I have 37992 and 37993,the foams and all packing are in parfect condition in the closets and both locomotives are in perfect condition in the display cases.It is to early to worry about the two Challengers,i will inspect them later.
Offline Dave Banks
#19 Posted : 12 September 2020 05:23:44(UTC)
Dave Banks
Well once I pulled the old foam out it was one bloody sticky mess. To my horror the instruction books & pamphlets were all covered in this oily mess as they were underneath the old foam. So I printed out what I could replace & binned the rest. This is the not so professional but functional result. Total cost AU$15.00 for foam & cutting. Its good to go for a long time now.
[img]UserPostedImage[/img]
D.A.Banks
thanks 4 users liked this useful post by Dave Banks
Offline Ross
#20 Posted : 12 September 2020 06:41:58(UTC)
Ross
Hi Dave,
Glad my prompt has helped save the loco. I haven't worried about new foam but would use your same method if the loco was to be transported by mail or courier which I don't think will happen soon. Maybe use thin felt cloth as a separator between loco and foam?
Ross
Offline Dave Banks
#21 Posted : 12 September 2020 07:23:00(UTC)
Dave Banks
Hi Ross, you certainly have been the savior. I recon the climate we are in is a contributing factor especially in the summer. The loco has a flat piece of plastic & when covered with that the foam just lets it slide past. Without the plastic I can imagine it would not slide past easily. The sponge holds the wooden base plate in place so no need for foam on the top of the loco. I suggest you guys address the issue before your spending hours trying to take the old sponge out & destroying all the booklets hidden under it. It reminds me of when we had bio degradable shoes in Australia. The mess sticky residue are very similar if left for too long.
Dave...
D.A.Banks
thanks 2 users liked this useful post by Dave Banks
Guest (12)
This page was generated in 0.614 seconds.
