Offline Bones
#1 Posted : 14 August 2020 12:58:21(UTC)
Bones
IMG_0189.JPGI found out how I could cut the but once I cut the normal aluminium I was left with this overlap
Is this normal
#2 Posted : 14 August 2020 15:59:19(UTC)
You need to cut both tubes at the same angle, otherwise they won't fit Cool
#3 Posted : 14 August 2020 17:24:16(UTC)
yes its normal. Its called geometry.
Offline Hannes Porsche
#4 Posted : 14 August 2020 20:31:46(UTC)
Hannes Porsche
Hi, rather, if you know the whole angle the final assembly has to be, then cut the individual tubes half that angle. This way they will meet with no overlap.
I just wonder how you are going to connect those after cutting. Please remember to remove all burrs after cutting.
BigGrin
Thanks.ThumpUp
HANNES
Offline Drongo
#5 Posted : 18 August 2020 07:15:30(UTC)
Drongo
Is this normal
Stick to bending bananas - sorry, I couldn't resist. Flapper Flapper Flapper BTW for non Australians, people who live in sunny, beautiful Queensland, are jestfully referred to as "Banana benders".
thanks 3 users liked this useful post by Drongo
Offline BruceOrrell
#6 Posted : 21 August 2020 15:32:09(UTC)
BruceOrrell
90 degrees required for a corner. Each needs to be cut at 45 degrees.
Offline Bones
#7 Posted : 05 September 2020 05:13:52(UTC)
Bones
Is this normal
Just to give you all some more info, I cut the aluminium using a formula that will give you a 90 degree cut from any other angle
The anodised piece was cut to 15 degree's and the other to match it so they form a 90 degree angle
They will be hidden anyway one the layout but I will use wood instead because I trim the other pice down
Edited by moderator 05 September 2020 21:42:00(UTC)  | Reason: Not specified
Offline Bones
#8 Posted : 05 September 2020 05:18:12(UTC)
Bones
The tubing was cut that way because my new layout has 2 levels and the top level is a 15 degree offset to the baseboard edge
The odd result may be from the mitre saw I used
Offline Bones
#9 Posted : 05 September 2020 05:20:13(UTC)
Bones
BigGrin
Thanks.ThumpUp
HANNES
I was going to try to clue them but the normal aluminium ended up with a slight curve in it
Offline Bones
#10 Posted : 05 September 2020 05:25:46(UTC)
Bones
Thanks Per but I did go to school and do understand a little bit about geometry - A right triangle has one side of 90 degree and the other 2 angles must equal 90 degree - 60/30 45/45
75/15
My father was railway engineer so he made sure I understood this
Offline Bones
#11 Posted : 05 September 2020 05:30:35(UTC)
Bones
Is this normal
A New South Welshman is also called cochcroach
A South Australian or West Australia is called a crow eater
I don't what they call NT or ACT people though
By the way moved to Qld from NSW
Flapper Flapper
Edited by moderator 05 September 2020 21:42:36(UTC)  | Reason: Remove repeated image
Offline DV
#12 Posted : 05 September 2020 09:09:20(UTC)
DV
Yup, we South Aussies are Crow Eaters but West Australians are Sandgropers
Tasmanians are people that visit Tasmania, and people born in Tassie (no jokes nowBigGrin BigGrin ) are Taswegians
Dusan V
#13 Posted : 05 September 2020 12:54:30(UTC)
75/15
Jeez. In that case you must ask your money back from the schooling! LOL
-Or ask your father again, unless he went to the same school, because in order to loose the overlap EACH PART MUST BE CUT TO THE SAME ANGLE!(*)
(*) Unless... that the two parts have different dimensions, in which case the two cutting angles change!
This page was generated in 0.500 seconds.
