Offline bobgiam
#1 Posted : 24 July 2020 19:27:31(UTC)
bobgiam
I can not seem to finding regarding how to connect an ESU Ecos controller to Marklin C track. Is there a polarity issue?
Offline scraigen
#2 Posted : 24 July 2020 20:03:59(UTC)
scraigen
As Märklin expects AC then polarity should not be an issue, I would put positive to the centre as that would allow other electrical items to use the rails as a common ground.
Must build something
#3 Posted : 24 July 2020 21:21:25(UTC)
Yes sort of with some decoders. Many switch decoders must have their "polarity" respected and otherwise will not function.
Märklin C Track have spade connectors marked B and O
On the ECOS side look at §6 of manual http://www.esu.eu/uploads/tx_es..._edition_II_eBook_01.pdf
You have two 2-pole connectors with O and B markings. One of the connector is for programming track and the other one for the main track.
So for main track you pick the appropriate connector and connect B on ECOS with B on track and O on ECOS with O on C track
Note: all recent loco don't care about "polarity by older switch decoders do
#4 Posted : 27 July 2020 10:16:35(UTC)
Try page 6 of the ECoS manual (page number may vary for different editions). Instructions for three-rail track apply to M track, C track, and K track.
Yes. The track current is not symmetric AC and polarity matters. Red or B have to go to the centre rail.
This page was generated in 0.612 seconds.
