Offline mikemasey
#1 Posted : 23 July 2020 00:41:21(UTC)
mikemasey
G-day all,
can anyone tell me how easy it would be to convert a HAMO to a Marklin AC.
Can I just fit a new pick-up shoe and move the pick up wires from one side and go through a rectifier to the DC moter.
I know that this will only give me one direction but that is fine.
I have done this with a old Triang loco and a Lima loco and it is all good.
Thanks.
Mike.
#2 Posted : 23 July 2020 09:13:59(UTC)
It is that simple. With some locos you only get current from one rail.
Offline rugauger
#3 Posted : 24 July 2020 14:43:54(UTC)
rugauger
HAMO locos have insulated wheels. You'll only get rail pickup from one side. It might affect how smoothly the loco will run. I have used conductive paint in the past to "bridge" the wheel insulators and thus get pickup from both rails.
Other than that, it really is that simple. If you want to add reversing later, Uhlenbrock have (or used to) a cheap electronic reversing unit.
Richard
#4 Posted : 24 July 2020 15:02:10(UTC)
That depends on the loco. With two-truck locos and such there are good chances that at least some wheels will pick up current from the other side without re-wiring.
Offline scraigen
#5 Posted : 24 July 2020 20:07:21(UTC)
scraigen
Connect the rail pickups together if there are two sets otherwise join the one wheel pickup to a part of the metal chassis and you will have ground from both rails, then you just need the pickup slider.
Must build something
Offline mikemasey
#6 Posted : 25 July 2020 11:19:45(UTC)
mikemasey
thanks for that.
I have converted a couple of Lima's and an old triang and it seems prety same same so thats good.
Thanks again.
mike.
Offline midwestbls
#7 Posted : 25 July 2020 23:51:55(UTC)
midwestbls
A HAMO 2-rail lok will have pickups on both sides. You simply need to wore the two wheel pickups together to the ground. Might only have pickups on one truck.
#8 Posted : 26 July 2020 05:50:40(UTC)
Not the ones I've seen.
One side has insulated wheels, that side will have pickups, the other side are not insulated so electrical conductivity is through the axle & chassis.
That's not to say that certain models may not have pickups on both side, and those with traction tyres present added challenges but I suspect that may be model-specific.
The couple I did were real easy and I just accepted that there 'may' be some limitations such as circuit tracks etc for block-control, level crossings etc - but nothing that can't be worked around BigGrin
Offline mikemasey
#9 Posted : 26 July 2020 11:28:04(UTC)
mikemasey
Many thanks,
As long as I have the wheels with or with out pick ups joined(electrically) and a separate feed for the (pick up shoe)ground then Ill be fine.
Mike.
Offline midwestbls
#10 Posted : 02 August 2020 00:35:48(UTC)
midwestbls
I've never opened one up to do a conversion (have several Trix RE460s waiting) ... but any DC, 2-rail locomotive MUST have pickups on both sides in some fashion as one rail is + and the other the - . How the "other side" transfers its + or - to the motor is immaterial, there IS a wired connection from both sides, both rails. That was my point.
Converting to AC, 3-rail, wiring the two sides together as - ("brown" in M lingo) and adding a pick up shoe for center-studs + is my understanding of the basics.
Offline mikemasey
#11 Posted : 02 August 2020 02:19:50(UTC)
mikemasey
Hi midwestbls,
yes I knew what you meant, haven't converted any Hamo yet but have plenty practice with others, Joeuf, Lima and even a Triang.
All work well if only in one direction.
Mike.
This page was generated in 0.751 seconds.
