Offline Den1z
#1 Posted : 19 July 2020 13:34:56(UTC)
Den1z
Hi, I bought some led lights to put into a 8820 ( bought with non functional lights, and found bulbs missing when body removed). However the circuit board inside is not what I expected in that it does not have the the metal covers with diodes underneath at each end. It also has long copper tongues at each end.
Is anyone familiar with this circuit board? Would it have been original or has it been removed from another loco? I will attempt to attach a photo of mine.
Offline Crazy Harry
#2 Posted : 19 July 2020 22:06:03(UTC)
Crazy Harry
It looks just like the instruction sheet and exploded views from the Marlin website. f1a84d238c0b6cad2af8045bd24992fa1434542599.pdf (440kb) downloaded 36 time(s). 071845c228fb821c6016139faf5cad651434542352.pdf (61kb) downloaded 25 time(s).
Offline Poor Skeleton
#3 Posted : 19 July 2020 22:26:04(UTC)
Poor Skeleton
I'm not familiar with the circuit board, but judging by the selector switch thing, it was originally from an electric loco. Also judging from the 180 Ohm resistor on the board, it is "expecting" LED lights.
In any case, my advice would be to fit the LED lights you have and see what happens. Whatever it is, it won't damage anything.
Hope this is of help
Chris
#4 Posted : 19 July 2020 22:41:20(UTC)
Poor Skeleton
Looking at the photo again, I'm certain that the circuit board is not original and is for an LED illuminated loco. The two copper "tabs" would normally contact onto the LED PCB mounted on the chassis.
Assuming you're using the CK LED boards, you'll need on of those tabs to contact onto the top of the CK module and the other tab to contact the bottom. The two contacts on each side of the PCB are connected together, so it won't matter which you use. If you choose the wrong contact going to each surface, it will make the module light up for the wrong direction of travel, though, so be wary of that.
As this is a bit of a "Frankenstein" model, there's no easy way of connecting and supporting the CK LED module. In your shoes I would just solder it to the tabs, having bent them into a suitable position, but if you're not confident with a soldering iron you may not wish to do that.
I notice you're in the UK, so if all else fails, I'm very happy to do the work for you if you can get the loco to me one way or another.
Good luck!
Chris
Offline Den1z
#5 Posted : 20 July 2020 02:22:49(UTC)
Den1z
Thanks folks for the input. From what I have found out and from comments on here confirming same I assume it is not the original circuit board I will experiment with connection, may need to remove or isolate the connections that would hit the bottom of the ckleds board. If all else fails I will look into sending it off to Chris.
Thank you.
#6 Posted : 20 July 2020 09:37:41(UTC)
Poor Skeleton
Thinking about this a bit more and looking at the service notes Crazy Harry linked to, I think you may be able to do this without resorting to soldering.
If you look at the picture on the bottom left of page 3 you can see the metal tabs of the original circuit board bend back on themselves to clamp the light module onto the chassis, and I think you should be able to bend the contacts of your PCB to do the same. The only complication is that you will need to insulate one of the contacts from the LED module. In your picture these are the contacts on the lower edge of the board in line with the 180 Ohm resistor (the black thing marked "181"). As I have access to these things, I'd probably fit a small piece of heat-shrink tubing, but you could do it with a tiny piece of insulating tape or even Sellotape.
Hope this is helpful and encouraging. As I said, very happy to help in any way I can.
All the best
Chris
Edited by user 20 July 2020 19:40:32(UTC)  | Reason: Not specified
Offline Den1z
#7 Posted : 20 July 2020 11:00:31(UTC)
Den1z
Thanks Chris, I will investigate further and experiment today, but that later solution sounds a good idea. Thank you.
Graeme
Offline Den1z
#8 Posted : 20 July 2020 17:28:45(UTC)
Den1z
All sorted now. As per Chris's suggestion I bent one of the tongues on each end to sit under the Ckled pcb and the other adjusted to sit neatly on top. As the chassis has contacts as well for the bottom of the bulb I placed a small piece of 0.5mm plasticard over them to insulate them from the bottom of the Ckled pcb. Took a couple of attempts to bend the correct tongue to get the buld lighting correct for direction. I imagine I will need to revisit as I can see vibration dislodging the lleds.
I had one panic moment when one corner would not show a light when the body was fitted, turn out the little lens had fell out from inside the body, luckily I found it on my work boards and its now glued back in with the light shining through.
Thanks again for all the help.
cheers
Graeme
link to video and then picture off led below.
thanks 1 user liked this useful post by Den1z
#9 Posted : 21 July 2020 09:58:20(UTC)
Poor Skeleton
All sorted now. I bent one of the tongues on each end to sit under the Ckled pcb and the other adjusted to sit neatly on top. As the chassis has contacts as well for the bottom of the bulb I placed a small piece of 0.5mm plasticard over them to insulate them from the bottom of the Ckled pcb. Took a couple of attempts to bend the correct tongue to get the buld lighting correct for direction.
Excellent, Graeme! Glad to hear you got it all working to your satisfaction.
All the best
Chris
Edited by user 21 July 2020 19:32:49(UTC)  | Reason: Not specified
This page was generated in 0.426 seconds.
