Offline husafreak
#1 Posted : 20 June 2020 16:41:39(UTC)
husafreak
I would like to service my steam loco, it is a 4-6-2 with tender built in 2018 from the #26928 set and the body needs to be removed to apply grease. I removed the four screws as shown in the instructions but could not lift off the body from the chassis. I pulled at the front and it didn't budge. I pulled a little at the rear and the cab came off. I could pick it up by the boiler and stacks and shake it but it remains together. Then I tried to gently pry up with a small plastic scraper type tool where I believe the separation should be but nothing would budge and I was not about to try harder and risk breaking something. I looked a various you tube videos but in every case the body simply lifts off. So obviously something is binding or there is a "trick" to it. Looking for any advice.
Edited by moderator 20 June 2020 20:23:46(UTC)  | Reason: Added bbcode for the product number/Webmaster
#2 Posted : 20 June 2020 20:02:31(UTC)
I don't have this specific loco but very similar ones from Märklin.
If you have removed the 4 normal screws as indicated (see below), then the body can be removed
What may be in your way: the body is sticking a little due to freshly painted part assembly (but you don't need loads of force).
Be sure to have removed the proper screws (happened to me in the past)
Offline husafreak
#3 Posted : 21 June 2020 02:01:54(UTC)
husafreak
Hmm maybe it is glued together by paint...
This page was generated in 0.216 seconds.
