Offline kytumba@gmail.com
#1 Posted : 07 June 2020 20:42:54(UTC)
kytumba@gmail.com
Hi All,
How can i find digital address of my old locomotive, Märklin H0 - 3086, to program in my mobile station 2?
Thanks & Regards
Kyt
Offline Martti Mäntylä
#2 Posted : 07 June 2020 22:54:29(UTC)
Martti Mäntylä
I assume the locomotive has been converted to digital. If so, the answer depends on the kind of decoder that was installed. Post photos if uncertain!
- Martti M.
#3 Posted : 08 June 2020 10:47:36(UTC)
kytumba@gmail.com
Thanks in advance for your fast reply.
It comes with my first "starter set" : Article No.29527 , and still original, it was an delta system.
Can you tell me if it needs any conversion to be used with mobile station 2 ? And what i need to do or buy to convert ?
King Regards
Kyt
Offline bph
#4 Posted : 08 June 2020 11:57:53(UTC)
King Regards
Kyt
Yes, you can use ut with the mobile station 2
try to enter the address 78 manually and use MM protocol. if that don't work you can also try 24, 60, 72
if that not works you need to open the locomotive and look at the dip switches. use the table below
https://www.maerklin.de/fileadmin/media/service/technische_informationen/Codiertabelle2.pdf
you can also take a picture and post it here and we will help you
Edited by user 08 June 2020 19:36:58(UTC)  | Reason: Not specified
#5 Posted : 08 June 2020 19:31:31(UTC)
Yes BPH answer is excellent.
You may have the following addresses:
- 24 for Electrics
- 60 for railcars
- 72 Diesel
- 78 for steamers (DIP 1=ON, DIP 2= OFF, DIP3= OFF, DIP4= OFF
If all switches are OFF then it will work only in analog mode
#6 Posted : 09 June 2020 10:32:15(UTC)
kytumba@gmail.com
Thanks all, now my locos runs in mobile station2.
https://www.marklin-user...digital/DIdeltaaddr.html
This page was generated in 0.386 seconds.
