Offline GenDemo
#1 Posted : 23 May 2020 06:25:18(UTC)
GenDemo
Hi All
I have a Marklin 24620 - Manual Double Slip which is not switching properly.
It is a manual switch, and if you flip the level slowly, it gets stuck. Its almost like you need to switch it with 'momentum' - and even then, it doesnt always switch.
I tried looking underneath if there might be something that is bent of something of the sort... but the mechanism is covered by a pastic sheet that seems to be 'plastic welded' in. I am scared to break it. Any advise on what to do? what to check? or how to get that cover off?
~GD
Offline Martti Mäntylä
#2 Posted : 23 May 2020 19:36:54(UTC)
Martti Mäntylä
Hi BD, sounds like the switch has picked up some dust and/or dirt.
I have used CRC electronic cleaner with some success to unstuck such cases; others may recommend better materials.
The plastic cover can be opened to clean the parts properly, but it is the last resort - it is tricky to reassemble the thing. (I've done it, and I don't want to try again.)
- Martti M.
Offline GenDemo
#3 Posted : 25 May 2020 10:29:31(UTC)
GenDemo
Thnx for your reply... how do I get the cover off though? just simply by kinda wedging it open?
#4 Posted : 25 May 2020 10:56:27(UTC)
Martti Mäntylä
The cover is fixed with snap joints, so it can be removed with a bit of gentle bending. If you do it, better take a photo right away to help you reassemble the parts. Like said, not recommended unless it is the last option remaining!
- Martti M.
Offline GenDemo
#5 Posted : 25 May 2020 10:57:34(UTC)
GenDemo
Will do, thank you :)
This page was generated in 0.224 seconds.
