Offline mgbeck
#1 Posted : 13 May 2020 00:25:21(UTC)
mgbeck
I'm working on digitizing my 3366 E52. I was using the 60901 kit, but I have a problem. Despite the fact that the permanent magnet is a perfect fit when attaching it to the wheel unit, it's too wide to fit when placing the wheel unit back into the housing. I need a thinner permanent magnet unit so it fits in the shell.
Any suggestions for a proper permanent magnet or has anyone successfully digitized the 3366?
Offline Dave Banks
#2 Posted : 13 May 2020 00:55:52(UTC)
Dave Banks
Have a look at this & decide which one is closest to what you want: https://www.ebay.com.au/itm/ausw...:mDA6JGIyMWAkEkoqNlFBHRA
You will need to use your old brush plate, armature & screws. I think #51961 is what you are looking for.
On the Dutch forum "3railforum" mention is also made of having to grind the permanent magnet down to fit.
Dave...
Edited by user 13 May 2020 06:58:03(UTC)  | Reason: Not specified
D.A.Banks
#3 Posted : 13 May 2020 01:11:33(UTC)
Originally Posted by: Dave Banks Go to Quoted Post
Have a look at this & decide which one is closest to what you want......
I think those are intended for use with the existing 3 pole armature, but may be the only option if grinding down the magnet from the 60901 kit isn't an option.
One other hint - try rotating the 60901 magnet 180 degrees and see if it fits better.
Offline Johnvr
#4 Posted : 13 May 2020 10:16:05(UTC)
Johnvr
You will notice that the permanent magnet has several layers of sheeting.
In the situation where a magnet is too wide to fit when replacing the cover back on, I have resorted to stripping off 1 or 2 layers of the permanent magnet.
You must be careful to lift a sheet off gently, in case you find that you need to replace it back again.
RegardsBigGrin
thanks 3 users liked this useful post by Johnvr
Offline ktsolias
#5 Posted : 13 May 2020 11:10:17(UTC)
ktsolias
Well known problem
The solution is here
https://www.marklin-users.net/intruder/
There go to "DIGITAL CONVERSIONS"
Then select
Märklin 3366 DB 152 034-5
All you need is there
Costas
thanks 3 users liked this useful post by ktsolias
Offline mgbeck
#6 Posted : 15 May 2020 07:30:48(UTC)
mgbeck
Yes you are correct. I figured that this is what I'd be doing. I was going to mill the chassis, but this is a better solution.
Originally Posted by: ktsolias Go to Quoted Post
Well known problem
Then select
Costas
This page was generated in 0.415 seconds.
