Offline thanos339
#1 Posted : 10 May 2020 17:25:22(UTC)
thanos339
Hey,
Today I found my minitrix V100 digital loco (minitrix 12152) which was on it's box for years without running. It has like almost 2 runs on it's back. When I tried to run it on my layout today, it didn't move. There is only a sound similar to when you accelerate barely enough to gain speed and doesn't change if I accelarate more. Lights and change direction mode seems to be working pretty good , so I guess it's something from the motor maybe? or there is not any good contact? Blushing
Thanks for your time
#2 Posted : 10 May 2020 18:17:48(UTC)
I can see 2 actions:
- check that the motor and its gears are not stuck: open the loco and access the motor, then gently try to rotate it. If there is resistance, remove the motor nd check where the sticking point is.
- clean the rails and the loco wheels with contact fluid or similar
Offline thanos339
#3 Posted : 10 May 2020 18:25:06(UTC)
thanos339
I opened the loco , motor seems okay with the correct lubrication and spins really good - didn't face any resistance at all.
Then I put the loco on my layout without the body but I can't see the motor spinning. Even if I push the loco gently with my hands nothing changed. Blushing
Offline thanos339
#4 Posted : 10 May 2020 18:56:22(UTC)
thanos339
[ u p d a t e ]
I found out that the problem isn't the motor (stuck etc) but there isn't any contact with the gears underneath. I really don't know why because the motor can't be more inside the body.
Offline dzug
#5 Posted : 13 May 2020 05:20:44(UTC)
dzug
Originally Posted by: thanos339 Go to Quoted Post
[ u p d a t e ]
You can check to see if any of the plastic gears have split or broken apart. There were a few Minitrix models that commonly had this problem a 5-10 years ago. My V80s were the worst for me.
Chris
This page was generated in 0.448 seconds.
