Offline bmc1275
#1 Posted : 30 April 2020 10:03:45(UTC)
bmc1275
Japan
I am using M track with CS2, to connect M track turn out and transfer table, I did like attached diagram. Everything seems working OK. However, I am not sure whether this is OK or not. Because my TGV POS 37790 mysteriously had some misbehaviour and funny smell. After that, LED in the car was dimmed (It had an accident and one of the wire was pulled, may be this is causing something).
Can I have your opinion or advice for this?
Marklin Electrical circuit.pdf (227kb) downloaded 67 time(s).
Edited by moderator 01 May 2020 09:33:55(UTC)  | Reason: Image added to post for convenience
Offline LoeM
#2 Posted : 30 April 2020 22:12:13(UTC)
LoeM
I think it's not wise to combine a digital and analog circuit with each other. The central station and the Titan Transformer share the ground.
It's possible this is disturbing digital signals from the CS2.
In the manual of the CS2 is a safe instruction: The CS2 must not be powered simultaneously from more than one power supply.
Also in the manual of the TGV POS, SNCF | Spoor H0 - Art.nr. 37790: This locomotive must never be supplied with power from
more than one transformer.
My advice: split the circuits. Don't use the M track for feeding analog bulbs in signals or switches. Give them a separate ground wire.
Best whishes
Leo
thanks 2 users liked this useful post by LoeM
#3 Posted : 30 April 2020 22:53:07(UTC)
Leo you are absolutely correct in showing the danger that the full power (i.e.: both poles) of an AC source poses when it is connected to a digital source. The digital source (CS1, CS2, CS3, rail box will "burn".
On the other hand it is also Märklin's official solution to drive their grade crossing in a digital environment by connecting the "Ground" (O or Brown) to both the digital source and the 0 plug of a Märklin transformer. The other transformer pole (Yellow of +16 VAC) is connected only to the yellow plug of the grade crossing.
With a neat cabling it is all fine. This is because the transformer is very well insulated from the digital source (floating voltage). This is also what we do when we connect all O poles of our digital layout no matter how many boosters we have and provided the B (or red) is specific to each booster zone.
Offline bmc1275
#4 Posted : 01 May 2020 01:53:27(UTC)
bmc1275
Japan
Best whishes
Leo
Thank you very much for your opinion. Yes, you are correct about not powering the same track from two power source. That is why I make yellow line from transformer absolutely separated from the track. However, it is not easy to insulate M track turnout bulbs alone as bulbs are using rail itself as a ground.
Offline bmc1275
#5 Posted : 01 May 2020 01:59:15(UTC)
bmc1275
Japan
Thank you very much for your info. Yesterday, my friend gave me exactly the same info and advice. My circuit is ok but make absolutely sure that transformer yellow is separated from CS2 red. If they short circuited, CS2 will burn.
Offline dominator
#6 Posted : 01 May 2020 07:52:53(UTC)
dominator
I HAVE RUN ALL MY POINTS FROM A BLUE TRANSFORMER FOR YEARS. i CAN RUN THE LOCOS FROM 2 ms2'S AT THE SAME TIME WITHOUT INTERFERENCE. Go ahead and wire it correctly. The same earthing on both systems works well. My set up has been working in analogue since 2000, and i added the MS2's about 4 years ago never looked back.
Dereck
Offline Johnvr
#7 Posted : 01 May 2020 10:47:03(UTC)
Johnvr
The circuit looks fine to me.
Remember that it is quite acceptable to run a digital circuit on the centre rail and an analog circuit on catenary and both of them using the same ground.
You circuit looks similar to me.
RegardsBigGrin
Offline bmc1275
#8 Posted : 01 May 2020 12:07:34(UTC)
bmc1275
Japan
Dereck
Thank you so much for sharing your experience. I also have blue transformer which is very old, but working fine. I like the digital very much however, I sometimes miss simplicity of Analogue.
Offline bmc1275
#9 Posted : 01 May 2020 12:12:13(UTC)
bmc1275
Japan
RegardsBigGrin
Thank you very much for your confirmation! Very encouraging.
#10 Posted : 01 May 2020 12:45:33(UTC)
With very old Märklin transformers, the critical point is to check the power cord. Those made around 1950 had a rubber-like insulation / coating that may come apart and be dangerous.
Before this power cords were made of fabric insulation also very dangerous.
The replacement must be made in a professional manner especially if used by children.
Offline bph
#11 Posted : 01 May 2020 15:15:06(UTC)
you might find Märklin technical tip 405, useful (in German)
https://www.maerklin.de/fileadmin/media/service/faq/Technik-Tipp-405.pdf
Offline bmc1275
#12 Posted : 01 May 2020 16:11:32(UTC)
bmc1275
Japan
Thank you very much for your info!
thanks 1 user liked this useful post by bmc1275
Offline aswap5
#13 Posted : 27 March 2021 15:16:19(UTC)
aswap5
India
Sorry for a very delayed post/question: if I use an entirely separate analogue circuit for motorised c-track points (turnouts) and digital for train operation with an ms2 it should be safe right? Thanks
Ashok
Guest (4)
This page was generated in 0.386 seconds.
