Offline thanos339
#1 Posted : 27 April 2020 16:24:06(UTC)
thanos339
Hello there,
I would like to ask if there is any way to run different brand loco on my minitrix (N Gauge) layout. What should I change in order to run them? is it possible?
I'm using TRIX Central-Control 66800 for my Digital locos and a trix transformer for my DC locos.
Thanks for your timeThumpUp
#2 Posted : 27 April 2020 16:55:17(UTC)
Make sure the couplers are compatible. Shouldn't be an issue for modern rolling stock.
Make sure the decoders support SX or DCC or DC. Decoders for N gauge should support DC plus either SX or DCC or both.
When buying older stuff on eBay or such, check coupler pockets and decoder capabilities carefully.
Offline thanos339
#3 Posted : 27 April 2020 18:11:35(UTC)
thanos339
So , if the couplers are compatible and loco is DCC shouldn't be a problem running , right?
#4 Posted : 27 April 2020 18:22:48(UTC)
Yep.
And if couplers are not compatible, but have coupler pockets then there is no problem either.
Offline thanos339
#5 Posted : 28 April 2020 00:54:53(UTC)
thanos339
Yep.
Thank you very much!!!ThumpUp
This page was generated in 0.258 seconds.
