#1 Posted : 16 April 2020 07:58:57(UTC)
Hi everyone,
I am staring at a pile of trains with wheels that need to be cleaned, and it made me thing to ask the forum their favorite methods/tips and tricks to do so effectively and rapidly?
To share mine, here is a list:
1- have clean track to begin with! It all starts here...
2- For older Marklin, a dremel tool with wire wheel attachment makes very quick work out of the wheels. Be careful if you have plastic trucks though!
I'm finding the newer marklin with the blackened wheel coatings don't do well with this tactic, and even worse is the plastic details which dictate wheel removal to begin with. (which is fine, but an extra step vs vintage marklin)
So what do you guys do to clean newer style marklin wheels?
Offline Janne75
#2 Posted : 16 April 2020 20:44:08(UTC)
Janne75
I use some electric cleaner with cotton tip to clean them usually. Care must be taken not to remove color from loco or it’s wheels. If I buy some second hand locos or rolling stock with very dirty wheels with a black thick layer of ”grit” I just use my finger nail to remove that black layer. It will just cut in pieces when turning those wheels against my finger nails so the cleaning is quite fast after this.
Janne
Online JohnjeanB
#3 Posted : 16 April 2020 21:57:46(UTC)
Remove with fine tweezers the hair and fibrous stuff near the axles, finish with a hard brush
For wheels, one method is to install the loco upside down on a pre-cut large sponge (so that the loco will hold in place). Power it with mini crocodile plugs.
Remove the big dirt aggregate (if any) with a small screwdriver very lightly pressed on the wheel surface
Repeat the process with a wooden flat stick (coffee stirrer) instead of the screwdriver.
Finish with a cotton swab with very little alcool /Isopropyl alcool (ATTENTION alcool will dilute many Marklin paints)
Clean the contact shoe with contact spray or contact liquid especially around the extremity buckles of the slider.
Offline owidgie
#4 Posted : 18 April 2020 21:16:04(UTC)
owidgie
Hello all.
I think you are on the right track (pun intended) with the Dremel.
I use it to clean wheels and armatures. The trick is to find SILICONE POLISHING bits for a Dremel. These are basically like the track cleaner/erasers (Bright Boy) for a Dremel. I get mine from jemcousa.com
These are accurate and make short work of dirty wheels. There are various shapes to choose from.
Rick
Online JohnjeanB
#5 Posted : 18 April 2020 21:46:59(UTC)
IMO using a dremel-like tool to clean wheels poses the following issues.
- on many non-driving wheels, the axle bearing is a piece of plastic that may be prematurely worn off
- on cars, most axles are conical resting on conical bearings. The wheel assembly bearing is a zone much less than 1 mm² which can be deteriorated when forcing a wheel to turn rapidly.
- on drivers the impact is not much better especially in the long run.
That is only my opinion having opened and repaired many times my Märklin locos and cars.
#6 Posted : 20 April 2020 01:54:21(UTC)
Originally Posted by: owidgie Go to Quoted Post
Hello all.
Rick
Brilliant Rick! Much better than a wire brush on the dremel. I'll have to order some up.
The other amazing tip is cigarette lighter fluid (which I had heard of using before) on "eye tees" which are a makeup thing of sorts that is much more durable than a q tip. I've ordered a box on amazon to try out!
Offline owidgie
#7 Posted : 21 April 2020 19:57:02(UTC)
owidgie
Great, I think they work well and it is fast.
What John said is correct but I put drag on the other wheel of the axle with my thumb so the wheel doesn't spin too fast when I do this. Also give the dremel about 25-30 degrees of angle and have it on the slowest speed.
Rick
thanks 1 user liked this useful post by owidgie
Offline jimwallace1652
#8 Posted : 01 May 2020 19:11:41(UTC)
jimwallace1652
I use Ronson Lighter Fluid. I dampen a white rag (T shirt) soak it with the Lighter Fluid , then place rag on a spare piece of M track or two and with my hand run the car back and forth on the rails.
Wheels on freight cars get cleaned and there is no damage plastic or metal on body of car. Most of dirt/grime comes off. Shirt gets very dirty!!!
I use a very small screw driver to gently chip off stubborn grime.
More Good news Ronson evaporates quickly and leaves no film.
Offline owidgie
#9 Posted : 01 May 2020 19:43:48(UTC)
owidgie
I recommend using smoke fluid for track cleaning - Smoke fluid is just kerosene, so save yourself some money and get a quart from your local hardware store.
If you insist on using Ronson lighter fluid, it is just Naphtha. So again save yourself some money and pick up a quart from the hardware store while you are getting your kerosene.
Rick
Offline Tom Jessop
#10 Posted : 05 May 2020 05:43:17(UTC)
Tom Jessop
While in Lockdown due to Corana Virus I have been ding some digging on other sites & came across this company in Switzerland that has some interesting accessories which included a vacuum track cleaner & another one which has felt ? pads for cleaning rail head suitable for either 2 or 3 rail in most gauges . No price mentioned but they seem to be the " Ants Pants " for cleaning work on the Modelbahn .
https://www.rail4you.ch/
Cheers Tom in Oz.
This page was generated in 0.534 seconds.
