Offline paul709
#1 Posted : 03 April 2020 02:10:36(UTC)
paul709
Trying to change station sounds on BR 218. Does the loco have to be on a programming track or can it be done on the main line. I currently do not have a program track set up. Changing cv’s at present has no effect. I’m using a CS 3+
Offline ktsolias
#2 Posted : 03 April 2020 09:17:58(UTC)
ktsolias
The original decoders fitted by Märklin are locked especially for the sounds, so you can't do any change with the CS3 or even with the lokprogrammer.
Only the retrofired decoders can be programmed and if they are mSD3
Costas
#3 Posted : 03 April 2020 09:45:50(UTC)
You have been a member since:: 16/02/2004(UTC)
I don't have a clear picture of your loco on my crystal ball. More information might be helpful (ref. number of loco, action you want to perform, &c.).
Some early ones can be changed with the LokProgrammer, including sound uploads. It could be that recent ones are not locked either.
Offline ktsolias
#4 Posted : 03 April 2020 13:17:24(UTC)
ktsolias
The early ones 6093x series were produced by ESU and are exactly the same like ESU LokSound 3, so is easy to program them with LokProgrammer.
The mSD2 plus the mSD3 variations are locked from the factory.
To unlock them so far (for dealers to add local sounds) you have to send the decoders to Märklin
There are rumors that Märklin will give the way to unlock the decoders to official dealers, but nothing so far..
Costas
Edited by user 03 April 2020 18:19:36(UTC)  | Reason: Not specified
This page was generated in 0.365 seconds.
