Offline QQQ1970
#1 Posted : 22 March 2020 02:59:24(UTC)
QQQ1970
The BR44 has a mfx decoder but no sound. Can I retrofit sound to the factory decoder or i need a new decoder?
#2 Posted : 22 March 2020 03:20:42(UTC)
you can't produce sound or download a sound file into a non sound decoder, its either a decoder or a sound decoder, it has nothing to do with mfx
so the answer is you have to buy a sound decoder sometimes Märklin has divided the decoder from a sound module which can be added later., whether it is with this loco I don't know
Offline Dave Banks
#3 Posted : 22 March 2020 10:40:23(UTC)
Dave Banks
Hi John, it states the following: #39882 - mfx digital decoder, version without steam locomotive sound
D.A.Banks
Offline ktsolias
#4 Posted : 22 March 2020 10:49:17(UTC)
ktsolias
What is the catalog No of the Loco???
Please if you can post a photo of the decoder.
Usually with Μärklin mfx decoders there are different versions for mSD and mLD
This I think is your case and if is an 21 pin decoder the only think that you have to do is to buy a 60975 decoder. The basic sounds for a steam loco are already installed. The installation is easy as far there is available space for th speaker and usually is in the tender.
If you want you can program or download specific sounds for your loco. Of course to do that you need the recorder programmer.
Which controller do you use??
Costas
Offline ktsolias
#5 Posted : 22 March 2020 10:52:23(UTC)
ktsolias
The 39822 has an mLd decode 21 pin
You can use the 60975 decoder. There is enough space for the speaker
Costas
This page was generated in 0.328 seconds.
