Offline markleando
#1 Posted : 07 March 2020 23:22:32(UTC)
markleando
Folks - hopefully someone out there may have a solution for this... I recently inherited several vintage Marklin locomotives, this has a lot of sentimental value for me and I am determined to make all of them work... but unfortunately the mid-80's 3102 does not go forward. I've taken the whole thing apart and have replaced motor, rotor, rotor brushes, grinder and reverse unit. The only thing I have not replaced is the door to the rotor. Even with all the new parts it continues not to move forward. In reverse however, it moves perfect. When the reverse unit engages the forward mechanism, the motor makes a loud buzzing sound and nothing happens... lights are on but it does not go forward. If anyone out there has the answer... much appreciated. Thank you-
Online bph
#2 Posted : 08 March 2020 01:20:40(UTC)
Its strange, but probably somthing that is posible to fix.
Have the 3502 myself, and its a very nice model, one of my favorits.
Here is just some ideas,
Have you cheked that drive rods and wheels are aligned, if you take out the rotor, does everything move freely in both directions?
When the rotor is in place can you turn the whhels by hand by ege moving one og the Tooth Wheels?
This might help you if you dont have it
https://static.maerklin.de/damcontent/52/bd/52bd5c8efb418e88d6adce2742318e171434542552.pdf
Offline Markus Schild
#3 Posted : 08 March 2020 11:08:14(UTC)
Markus Schild
I'm very sure you have an electric problem. One of the soldered connections from the field-coil is broken: The field coil has three wires: One is connected to one brush with a short cable. The other two are connected to the reversing switch. Check these two connections. Either one oft wires is broken or the connection to the reversing switch is loose. It is also possible that the fault is in the reversing switch itself. But that is not happening frequently.
Markus
Offline markleando
#4 Posted : 08 March 2020 14:21:51(UTC)
markleando
Thanks folks - I figured out what it was... combination of misaligned gears and the brushings with a slight bad contact.
It's restored after 40 years of being in a box!
Thanks for the locomotive diagram... I've been looking for that for a while.
Thanks again everyone -
thanks 1 user liked this useful post by markleando
Marklin 3102 (BR-53) upgrade to digital (Digital)
by marklin-ho 26/09/2016 07:29:47(UTC)
WTK: Cosmetic Differences Between Marklin 3102 and 3502 Borsig 53 ? (Collector's Corner general)
by Roman 10/01/2014 01:30:16(UTC)
This page was generated in 0.351 seconds.
