Offline Pfalzbahn
#1 Posted : 17 February 2020 23:45:35(UTC)
Pfalzbahn
While I've done this some years ago I am unable to upload pics to my CS2. I put some 15 png engine pics on to a USB stick and plugged it into the CS2.
How does one proceed now?
I appreciate your help.
Pfalzbahn
Offline TEEWolf
#2 Posted : 18 February 2020 00:34:01(UTC)
Pfalzbahn
Maerklin published Technical Tipp #314 for this topic. They know some people forget it, some have never known before.Laugh
https://www.maerklin.de/...aq/Technik-Tipp-314b.pdf
Seriously, if you need help for translation - ask. You know the translating software DeepL?
https://www.deepl.com/translator
Offline Pfalzbahn
#3 Posted : 18 February 2020 01:26:31(UTC)
Pfalzbahn
Thanks a lot for your advise. I proceeded as described in your link and it worked fine until this stage:
Now I am waiting already 20 minutes and the bar doesn't complete fully to the right yet there is a statement that the upload is complete? I am confused.
However the link claims that it may take up to an hour. So I am waiting.
BTW, ich spreche und schreibe natürlich auch Deutsch.
Many thanks, vielen Dank,
Pfalzbahn
Offline TEEWolf
#4 Posted : 18 February 2020 02:04:30(UTC)
Pfalzbahn
All right, this is the best solution knowing the language itself. Smile I know the CS 2 is not the fastest, but so slow?RollEyes Then it makes sense doing not so often an upload of pictures.
Or buy a CS 3. It is uploading in seconds. Did it with my IC 2 Dosto cab forward car 43483, which has a mfx decoder inside which is handled by the CS 3 like a mfx loco, but is not listed in the database.
Offline PMPeter
#5 Posted : 18 February 2020 04:08:13(UTC)
PMPeter
Once I get the message that the Update is Complete I click the green check mark and am done with it. I never worry about where the bar is. If the check mark is not green then there is a problem.
I believe you also need to shut the CS2 down and restart it in order for the new icons to display.
Offline dickinsonj
#6 Posted : 24 February 2020 01:43:29(UTC)
I updated the software on my CS2 last week and it did not proceed as it has in the past. It partially finished the update and then it just hung, with me waiting on it and it waiting on me. Confused
The green checkmark was not functional (greyed out) so I clicked the "More" button which was basically my only option. That started the update process again and then it completed successfully. I have updated this CS2 numerous times and this was the first time that has happened. Perhaps the update process has changed and not been documented?
#7 Posted : 24 February 2020 05:26:40(UTC)
Sometimes this is needed when the GFP (booster) section also needs updating, although I don't recall it being quite the sequence you are describing.
#8 Posted : 24 February 2020 07:25:25(UTC)
This is normal, when there is core/kernal/operatingsystem updates to apply that require/force a FULL reboot and update.
Most of the time we have updates, they are only the component "Apps" that run on the operating system.
Every now and then, usually at the same time as a major version number change 1.xx.xx -> 2.xx.xx but not always, you will get what you describe - i.e. you have to press the More button to "Shutdown and update"
Offline dickinsonj
#9 Posted : 24 February 2020 12:56:55(UTC)
Thanks for the info Peter. That makes sense and that is exactly what happened, it rebooted and then finished the update. The part that was strange for me was that I don't recall ever having to do that with any other updates over the five years I have used this CS2. Of course the issue could be in the user's memory and not in the software. Blushing
The other odd aspect was that I saw (what I assumed) was a new software version for the TFP but there was no sequence of requests and permissions to update the TFPs in my boosters, as has happened in the past. I have no idea why you would not want all of the TFPs running the same software or why you would need to grant permission, but that has happened many times in the past. All's well that ends well however and everything is working just fine. ThumpUp
Maybe I am just jumpy from enduring the painful process of getting feature updates on my Windows 10 box. BigGrin
This page was generated in 0.435 seconds.
