Offline James1192
#1 Posted : 17 January 2020 21:20:01(UTC)
James1192
Does anyone know a reason why a quality Brawa 3 rail locomotive wouldn’t work with a simple Marklin Train Set IR digital control?
I ask because I have a Brawa AC loco bit no marklin Digital equipment to test it on. I would be quite happy to buy
00748 + 66201 to run it but I guess there is little point in spending $20 if it is not going to work!
#2 Posted : 18 January 2020 00:00:24(UTC)
The IR controller only has 4 addresses that it can select. your loco is probably set to some other address.
Check the IR control operating instructions to find out how to change the address. Make sure there is only one loco on the track when you do otherwise all locos will be set to the same address.
Offline James1192
#3 Posted : 18 January 2020 07:51:06(UTC)
James1192
I believe the Loco I have will be factory set to ‘3’ - so in essence you are saying it should work with one of these simple controls
Thank You
#4 Posted : 18 January 2020 08:49:28(UTC)
'3' is normally the default address for a loco using DCC. The Marklin IR controller will only work with the Marklin Motorola protocol, and is limited to 4 of those addresses
Position 1 = MM-Address 78
Position 2 = MM-Address 72
Position 3 = MM-Address 60
Position 4 = MM-Address 24
You need to set your Brawa loco to one of the four above MM addresses.
Offline James1192
#5 Posted : 18 January 2020 09:27:06(UTC)
James1192
And I can do this with 00748 + 66201?
#6 Posted : 18 January 2020 09:36:15(UTC)
66201 is a power pack so has no bearing on this discussion. 00748 is the IR controller, apparently you can program addresses with it but I have no idea how. Check the manual.
#7 Posted : 18 January 2020 09:47:55(UTC)
Yes, you can program the address of your loco, using the infrared set to give the loco one of the 4 addresses;
but I don't think it will work for a loco decoder set up for DCC.
If your loco is set up for MM, you can use the infrared set to change the decoder to one of the 4 above mentioned MM-addresses.
From the manual:
Changing an Address:
If you have 2 locomotives with the same address, you can
change the address for one locomotive as follows:
Unplug the transformer. Set the address switches (9*) to the
desired address. Press the button „Change Direction“ (7*). Hold
this button pressed down while the lens (8*) on the IR-Control
shows to the receiver, and plug the transformer back into the
wall outlet.
Release the button as soon the light comes on. The programming
procedure is displayed when the light comes or blinks. As soon
as the light goes out, the programming is turned off. The locomotive
can now be run with the new address.
Offline James1192
#8 Posted : 18 January 2020 10:03:36(UTC)
James1192
Well this is getting a bit off course for me
The Locomotive is a Brawa AC Loco - straight from the box as produced - would it be programmed to work on simple Maerklin digital control?
#9 Posted : 18 January 2020 10:06:41(UTC)
Check the loco's manual to see if it has a default MM address. If so, then proceed as above. If not you might need to find someone or a dealer with a MS2 or CSx who can change the loco address for you.
Offline James1192
#10 Posted : 18 January 2020 11:09:01(UTC)
James1192
Looking closer Hinweise says
Digitalbetrieb: Fahrbetrieb Vorwaerts-Stopp-Rueckwaerts
ADRESSE:”03” (DCC and Maerklin Motorola)
So I guess it does have a MM address of 03 and so could be changed to 78 / 72 / 60 / 24
Thank you Big Biker aus Neuseeland and Mr Purrelum fuer die Erklaerung
#11 Posted : 18 January 2020 15:36:23(UTC)
but what is the catalogue number? That may help identify the manufacturer of the decoder.
Offline James1192
#12 Posted : 18 January 2020 22:21:16(UTC)
James1192
40635. I have had some unhappy experiences with Brawa’s 3 rail version of this locomotive. It has the oddest ‘skater’ which although is nice and small and hides behind all the wheels (Great!) it can easily become dislodged. I returned one to Brawa previously and they sent it back to me with a Skater attached that just looked like Maerklin 3087 i.e. Chunky and on full display in front of the wheels.
A second sale price locomotive came with the identical problem with skater. It worked perfectly, though and I sort of accepted it as it was, but at the turn of the year I decided to replace it with a DCC Model 46098 (BBOe Schwarz) to use alongside my Fleischmann 4098 and beautiful Fleischmann coaches. The AC loco was sold on ebay but then the buyer asked for a return because “the skater was broken”
So I have this locomotive back at home - and she is really pretty, and I would happily use it alongside 3087 as a ‘Spielzeugeisenbahnlok’ but I no longer have a decent AC controller!
Offline James1192
#13 Posted : 29 January 2020 23:57:19(UTC)
James1192
I got rid of it, I don’t need the expense of trying to do something about it!
#14 Posted : 30 January 2020 16:21:03(UTC)
Did you even try changing the address with the IR control? Just getting rid seems somewhat drastic if you didn't.
#15 Posted : 30 January 2020 17:15:42(UTC)
It sounds like James' heart wasn't really in it. It's a shame as Brawa locos are at least as good as Marklin. I have two in my collection and in both cases I've changed the addresses with my MS2.
Offline James1192
#16 Posted : 30 January 2020 18:55:47(UTC)
James1192
I have the beautiful locomotive as a DCC Model ‘BBeO’ Black with identical side tanks and with no issues, so the 3rail version was just becoming a ‘headache’ really. I know I might be vilified on here for saying this,but, life is neat and a lot sweeter without sliders!
thanks 1 user liked this useful post by James1192
#17 Posted : 30 January 2020 20:24:18(UTC)
To each his own!
Offline TEEWolf
#18 Posted : 30 January 2020 22:41:53(UTC)
Well I have to try tasting one of my sliders, if it is really sour.Laugh
Before see this little video:
Important: press down the bar for changing the direction as long as you stick the power supply into the track current feeder box (base station).
This video is without words, only subtitles. For reading in English see the link to this manual from Märklin start-up 29184 (I do have this set by my own) and read point 7.3 "Changing an adress".
https://static.maerklin....ee29b90d811553158290.pdf
Offline James1192
#19 Posted : 31 January 2020 08:25:19(UTC)
James1192
OK OK! Maerklin Start Up IS neat - and I do actually like the control function here. It is a delightful way in getting people interested in operating and owning Model Trains! Maerklin are very good at what they do.. The idea of running some Start Up Engines simultaneously is great. I know the rationale of offering the Lego and Jim Knopf variants recently, but it does seem a shame that they seem to have skipped the option of a cheaper starter set with a regular Steam Tank Engine with Sound Function. I thought one would have naturally followed the DHG 700 example - but hey, Maerklin know better than me at what is going to sell!
This aside, however, when I pay a lot of money for an intricate locomotive with Digital operation - aesthetically - I do not like a slider poking out under what, these days, can be almost perfection. But that’s just me!
This page was generated in 0.554 seconds.
