Offline geir
#1 Posted : 11 January 2020 17:47:36(UTC)
geir
I have made an event.When the switch trigger, there should be 10 sec delay before G2 are powered.
But there is no delay.
#2 Posted : 11 January 2020 22:22:08(UTC)
If you watch the "status" dot I believe you will find that there IS a delay as the event runs.
It is just that the delay as specified is AFTER the event
You can debate the non-intuitive logic and presentation, but either way you need to load a "dummy" item at the start of the event , which has the delay before the action you want delayed
Offline geir
#3 Posted : 11 January 2020 22:57:31(UTC)
geir
Tnx a lot clapcott:)
I used an anouncement with delay as a dummy and it works.
Offline geir
#4 Posted : 12 January 2020 16:42:16(UTC)
geir
Is there any other "dummy" item to use? which have a delay function.
This page was generated in 0.198 seconds.
