Offline Tranguru
#1 Posted : 07 January 2020 11:43:03(UTC)
Tranguru
I am new to the forum.
A few days ago I got took out my old train set, put some tracks together and tested the trains after about 30 years sitting in a box...
A lot maintenance had to be done BigGrin .
I saw that there is a high efficiency motor kit with a permanent magnet.
so here are my questions:
- assume that motor runs on DC then
- I will also need to install this small electronic module to replace the direction inverter
- this module rectifies the AV voltage from the tracks to DC to for motor?
- any tips or tricks anyone has?
Robin
Offline Henrik Schütz
#2 Posted : 14 January 2020 13:02:48(UTC)
Henrik Schütz
You replace the motor and the relay with the high efficiency motor and a decoder, then you run as before with your old transformer. In order to really benefit you need to replace the transformer with a digital controller, google "märklin mobile station 2" then the fun begins.
Henrik Schütz ,Stockholm
#3 Posted : 14 January 2020 13:34:39(UTC)
Hi Robin
Warm welcome to the forum.
As Henrik already wrote the direction inverter must be replaced and the motor needs to be converted from AC- Universal motor to DC 3 of 5 pole motor.
For quite a large number of locos produced by Märklin (with a drum collector) Märklin provides an economical upgrade set (60760) including a 5 pole DC motor upgrade kit and an FX decoder (36.90€ by MSL)
For older locos with a flat collector you need a motor -60943 for small collector or 60944 far large collector and a decoder mLD3 like the 60972 to be installed in the location of the old direction lnverter.
Of course there are a lot of other possibilities and I did not mention the case of very large motor Märklin locos (DL800, CCS800, ST800, RE800, 3015).
In all cases the above-mentioned decoders will rectify the voltage and provide DC drive to the motors
I hope this helps
This page was generated in 0.307 seconds.
