General topics
Digital
mfx+ with Intellibox not responding to Motorola address
Hi I am asking on behalf of a friend who has the Märklin „Köfferli“ 39520Manual: https://static.maerklin.de/damcontent/27/eb/27ebd7bab692c584523c0929dacf46f11572440800.pdfHe runs his layout using Motorola only using an Intellibox (first version). (Because some signals gave trouble when DCC was also present) He has set CV 50 = 4 - which disables mfx and enables DCC & MM He has tested the loco on some track powered by the Märklin 6021 - which is MM only and it works fine. But on his Intellibox powered track, it won't respond. Suspecting that his Intellibox may be sending some DCC packets out, I have asked him for the values of special options 10, 12, 22, 25 & 907 Any other ideas as to why this loco may not work on the IB? Could it be "World of Operation" that may need to be disabled? (I don't see any setting for that though) |
Hello Dale, I do not have much experience with ESU's Intellibox. But as you know I got a CS 3+. Maerklin recommends in its manuals and/or books to switch of all not needed track formats at a CS 3. Because they may cause some trouble. I do not think it has directly to do with the mfx+ format, but perhaps with mfx itself. As you see in the manual the setted track format priorities from the manufacturer. It is always mfx on the first place. As you write, only the IB makes some trouble. So why not switch it completly off for the IB? Run the loco only with DCC in a way the IB is forced using only DCC. Give it no chance for any choice selecting by itself the use of a track format. The main setting for the controller is using the track format by its installed priority levles. BTW, from you a very nice article in German in the new “Digitale Modellbahn” (DiMO) 01-2020 page 60 ff about the “Bahnsteiganzeiger”! Even your "Wilsnack Hbf" picture is seen on the title of the paper. https://docplayer.org/16...oled-bildschirmchen.htmlOK, we know this article from your homepage already. Nevertheless for myself it is an easier reading.  Oh, just write the German word - Bahnsteiganzeiger - into Google and see the pictures coming up. ciao Wolfgang P.S.: did you try CV 50=5 or 6 or 7 too - perhaps this has an influence for an IB?
I had a similar problem with croco insider 39567, I disabled the mfx and put a long address on DCC, and it didn't work for me. So, I left it with the default address in DCC and MM, and drove it in MM when it responded, which took a few tries, I put the long address in DCC and it worked fine.
Anyway after a while, without using it, it did the same to me again, it seems that if this long time without using it tends to forget the DCC address, with the BR 65 it happened the same to me.
See what version of software the IB has, mine has the latest one, 2.01; it would be better to update it since with this version you can access all the functions.
And I use DCC and MM addresses for the locomotives, and the turnouts and signals all in MM, and it works fine without problems.
IB is from Uhlenbrock.
best regards
 1 user liked this useful post by amartinezv
When i use even Märklin on the tracks with the CS3 i make sure to disabled unnecessary protocols and use only one protocol set at the locomotive decoder. Märklin recommended this way too, because to avoid digital interference with too many protocols enable. |
H0 DCC = Digital Command Control
the CV 50 does not give the option of disabling DCC. the value of 4 disabled everything else except DCC and MM so to run using MM DCC has to remain enabled.
He sent me the SO values today and I believe that he has to set SO 22 = 7 , so 25 = 3 and SO 907 = 1 to ensure that no DCC packets are sent out.
He will be trying those values later today. |
Thanks Wolfgang! It has been an honor to have it translated for the German train press. They saw the article in a UK publication and asked to publish it also! I have another article I have sent to them too! |
 1 user liked this useful post by DaleSchultz
Joined: 23/07/2014(UTC) Posts: 8,510 Location: ENGLAND, Didcot
Originally Posted by: DaleSchultz  the CV 50 does not give the option of disabling DCC. the value of 4 disabled everything else except DCC and MM so to run using MM DCC has to remain enabled.
No it doesn't mean anything of the sort - check the Marklin documentation for the decoder. You cannot disable the protocol that you are using to program the decoder, so if you are using the Intellibox it will be using DCC methods for programming, so you cannot disable DCC. If you are programming on a Marklin controller with DCC disabled then you will be able to disable the DCC protocol in the decoder.
 2 users liked this useful post by kiwiAlan
Originally Posted by: TEEWolf  I do not have much experience with ESU's Intellibox. Neither have I, but I had the Intellibox made by Uhlenbrock earlier... |
Juhan - "Webmaster", at your service... He who asks a question is a fool for five minutes. He who does not ask a question remains a fool forever. [Old Chinese Proverb] |
 1 user liked this useful post by Webmaster
my friend has reported that with my suggested changes to some special options, his loco is now working fine!
Originally Posted by: kiwiAlan  Originally Posted by: DaleSchultz  the CV 50 does not give the option of disabling DCC. the value of 4 disabled everything else except DCC and MM so to run using MM DCC has to remain enabled.
No it doesn't mean anything of the sort - check the Marklin documentation for the decoder. You cannot disable the protocol that you are using to program the decoder, so if you are using the Intellibox it will be using DCC methods for programming, so you cannot disable DCC. If you are programming on a Marklin controller with DCC disabled then you will be able to disable the DCC protocol in the decoder. uh, what? I actually included a link to the documentation that shows that the value 4 leaves only MM and DCC enabled. They lump MM and DCC together into one column (bit). You cannot disable DCC and keep MM or vice versa. I know one can't disable the protocol being used to change the CV, but that is irrelevant. It is just a reminder to use a different protocol to program the CV. In his case he can't use mFx to set the CV, but since he only has access to MM and DCC, it is not an issue. You cannot disable DCC and keep MM enabled. |
Originally Posted by: DaleSchultz  uh, what? I actually included a link to the documentation that shows that the value 4 leaves only MM and DCC enabled. They lump MM and DCC together into one column (bit). You cannot disable DCC and keep MM or vice versa.
You can use only one protocol by save mfx in value 8 at adress CV 50. I prefer one protocol in the decoder because of pure signal contact alone on the digital tracks. You can always disable DCC protocol or MM in the CS3 system settings too. In this case the decoder cannot use some of the protocols. I recommended ac and dc protocol disable because they are waste on the digital tracks. |
Joined: 17/09/2006(UTC) Posts: 18,778 Location: New Zealand
Originally Posted by: Webmaster  Originally Posted by: TEEWolf  I do not have much experience with ESU's Intellibox. Neither have I, but I had the Intellibox made by Uhlenbrock earlier... I have an Intellibox made by Uhlenbrock (an early 650 model) but I don't know where you can buy an ESU one....
Originally Posted by: TEEWolf  .....from you a very nice article in German in the new “Digitale Modellbahn” (DiMO) 01-2020 page 60 ff about the “Bahnsteiganzeiger”! Even your "Wilsnack Hbf" picture is seen on the title of the paper. I wondered why the picture of the BR111 in S-Bahn colours rang a bell, now I know why. Should have checked the author's name!
 2 users liked this useful post by Bigdaddynz
Joined: 16/02/2004(UTC) Posts: 15,466 Location: DE-NW
Originally Posted by: DaleSchultz  You cannot disable DCC and keep MM enabled. You cannot disable DCC using DCC. You cannot disable MM using MM. You cannot disable mfx using mfx. You can disable DCC using the MM protocol leaving MM active. Can definitely be done using the 6021. Can most likely also be done with the Intellibox. |
 1 user liked this useful post by H0
 Page from the manual Dale refers to. Not sure what it means by "DCC or MM" or what happens when 4 is written to CV50. Does it just enable both protocols (which is the inference) or does it enable the one you are programming with (assuming you are using either MM or DCC to program)?
Originally Posted by: Bigdaddynz  Page from the manual Dale refers to. In the manual for the 60972 decoder you find separate tables for MM programming and DCC programming. https://static.maerklin....e982b774421569315494.pdfBit 2 applies to DCC only when using MM programming and it applies to MM only when using DCC programming. There are two different bits in the decoder, but the interface hides one of these bits so you cannot lock yourself out. In the loco manual they made a combined table that can give the impression that MM and DCC share the same bit. |
 2 users liked this useful post by H0
I suppose Intellibox first generation need to been update to handle with the new generation decoder? The old digital system cannot handle with all digital decoders without problem when the old system has not been upgraded. |
Originally Posted by: Goofy  I suppose Intellibox first generation need to been update to handle with the new generation decoder? The old digital system cannot handle with all digital decoders without problem when the old system has not been upgraded. Hi I have the first generation IB, and I do have it updated to the latest version, 2.01, but as far as I know when I read the review notes I don't remember that at any time there were problems handling the newest decoders, it was to fix or implement new features. One of the last updates gave an easier and more direct access to the functions of the decoders, but in any case the access was there. Best regards |
Originally Posted by: Goofy  I suppose Intellibox first generation need to been update to handle with the new generation decoder? The old digital system cannot handle with all digital decoders without problem when the old system has not been upgraded. I suppose you have very little experience with the Intellibox. DCC is DCC and why should a standard-compliant controller require an update to handle newer standard-compliant decoders? Well, are the latest Märklin decoders standard-compliant? ESU offers an update with workarounds for bugs of recent Märklin decoders, but AIUI this applies to mfx only, so no need for Uhlenbrock to add workarounds to their DCC controller. |
Originally Posted by: H0  Originally Posted by: DaleSchultz  You cannot disable DCC and keep MM enabled. You cannot disable DCC using DCC. You cannot disable MM using MM. You cannot disable mfx using mfx. You can disable DCC using the MM protocol leaving MM active. Can definitely be done using the 6021. Can most likely also be done with the Intellibox. Not according to the documentation. If disabling say DCC what value would you put into CV 50 then? It sounds like people are suggesting there are two CV 50 registers, one visible to MM and one visible to DCC. If so then the value of 4 would have eliminated the DCC capabilities if my friends loco. It did not. |
Originally Posted by: DaleSchultz  It sounds like people are suggesting there are two CV 50 registers, one visible to MM and one visible to DCC. If so then the value of 4 would have eliminated the DCC capabilities if my friends loco. It did not. The value 4 enables DCC, it does not disable it. AIUI you do not get direct access to the memory through CV 50, there are at least 5 bits and CV 50 accesses a subset of 4 bits. Setting CV 50 to 0 under MM protocol will disable DCC, but leave MM active. Setting CV 50 to 0 under DCC protocol will disable MM, but leave DCC active. With mfx you can enable or disable DCC and MM independently, but cannot disable mfx. |
Thanks Tom.
That is how they should have written the documentation!
Originally Posted by: H0  Originally Posted by: Goofy  I suppose Intellibox first generation need to been update to handle with the new generation decoder? The old digital system cannot handle with all digital decoders without problem when the old system has not been upgraded. I suppose you have very little experience with the Intellibox. DCC is DCC and why should a standard-compliant controller require an update to handle newer standard-compliant decoders? Well, are the latest Märklin decoders standard-compliant? ESU offers an update with workarounds for bugs of recent Märklin decoders, but AIUI this applies to mfx only, so no need for Uhlenbrock to add workarounds to their DCC controller. It is not first time customer who use Intellibox first generation do have problem. Simple understand there has been lot of problem by use even Uhlenbrock digital accessories. You should check if Intellibox does really works? Owner to Märklin old system 6021 did also got some problem to control competitors digital products. If the problem in the Intellibox does still keeps on, you have to fix the problem. |
Joined: 01/02/2004(UTC) Posts: 7,465 Location: Scotland
Maybe we should have a thread just for Intellibox users who can then help each other without non users (like me) getting involved. |
Take care I like Marklin and will defend the worlds greatest model rail manufacturer. |
 1 user liked this useful post by David Dewar
Just to summarize here,
The issue was a Märklin documentation problem. Their documentation is misleading at best, essentially wrong. As Tom pointed out, can discern the discrepancy by looking at the 60972 decoder documentation which is more comprehensive.
The Intellibox has nothing to do with the problem, it was simply the device that showed the problem.
I still use the first version of the IB, it works perfectly, and to date I have not heard of another controller as successful as the IB.
Suggestions that one should check the IB is working to someone who has used one for over 2 decades and capable of using logic to explore potential causes is rather insulting, especially coming from someone who constantly has problems getting anything to work from any manufacturer. Despite not even having even seen the loco that was not working well, I was able to suggest configuration changes that worked around the decoder documentation problem, remotely.
Thanks !
 4 users liked this useful post by DaleSchultz
You have been told many times that this forum allows talking about anything that can be used with Märklin products. You have a long-standing reputation for derailing threads and reducing the S/N ratio and you lived up to our expectations once again. |
 3 users liked this useful post by H0
Originally Posted by: David Dewar  Maybe we should have a thread just for Intellibox users who can then help each other without non users (like me) getting involved. This was a thread for Intellibox users - goofed up with some not so helpful remarks. |
Joined: 27/10/2004(UTC) Posts: 944 Location: Burney, CA
We use the Intellibox II on the ETE modules here in the Bay Area. It can be a little buggy. The problems with MFX Loks with the newer decoders were deciphered early on in our experience. The protocols ARE documented in the Marklin instruction book, but not immediately obvious to the casual user of the product.
The above being said there are certain of my older MFX Loks that have difficulty with the intellibox and will not run or many functions are inaccessible. There are some other problems as well, but no one has mentioned them so I won't either.
I personally am still using a CS2 as it is adequate for my needs, but it's starting to break and need repairs, so an update is due.
From the People's Republik of Kalifornia |
Originally Posted by: mrmarklin  The above being said there are certain of my older MFX Loks that have difficulty with the intellibox and will not run or many functions are inaccessible. The functions that are inaccessible with the IB are also inaccessible with the 6021. This is by design coz Märklin want you to buy a new controller. If locos run with a 6021 but not with an IB then there is an issue with the IB. All my "mfx" locos run with the IB - most of them require using MM and some functions might be inaccessible, recent ones run using DCC. |
General topics
Digital
