Offline morsing
#1 Posted : 05 January 2020 17:19:59(UTC)
morsing
Finally got to a stage where I can hook up my Central Station to some track (woot \o/) but am quite puzzled to see 12.3V from the CS3. I thought it should be 19-20V?
Have I missed something? Is this a problem?
Henrik
P.S. I'm also slightly confused to see 5V on the sections I have isolated with Marklins little insulators.
P.P.S. Ok, scrap that, I put my meter from "V~" to something called "Auto-V LoZ" and it's 17V now, and 0V on the isolated sections. I obviously don't know how my meter works, off to Google...
Marklin C-track + CS3+
#2 Posted : 05 January 2020 17:51:55(UTC)
I use power supply 60061 and it feeds 19 VDC.
In my CS3 it shows same power feeds like power supply.
Offline Copenhagen
#3 Posted : 05 January 2020 19:36:05(UTC)
Copenhagen
I suppose that the voltage could easily be lower out on the track depending on your use of feeder wires.
(Henrik... that sounds like a Scandinavian name).
Offline morsing
#4 Posted : 05 January 2020 19:42:08(UTC)
morsing
I measured it directly from the CS3 as well and it is Scandinavian!
#5 Posted : 05 January 2020 19:44:06(UTC)
digital track voltage is not sine wave AC, so meters that try to calculate voltage assuming a sine wave shape will not give an accurate result.
Offline morsing
#6 Posted : 05 January 2020 19:58:30(UTC)
morsing
I've Googled true RMS meter and it should definitely be better than a cheap meter at non-sine wave A/C.
Still not sure why the V~ setting gives such an in-accurate reading.
Offline Copenhagen
#7 Posted : 05 January 2020 20:04:04(UTC)
Copenhagen
Just checked on my layout. The CS3 says 19,1 and the meter says 17,7 (on ordinary AC setting).
Offline morsing
#8 Posted : 05 January 2020 20:09:39(UTC)
morsing
Is that a true RMS meter?
Offline Copenhagen
#9 Posted : 05 January 2020 20:23:58(UTC)
Copenhagen
It's just a cheap meter (called multimeter in my country).
#10 Posted : 05 January 2020 21:43:51(UTC)
It is a combination of what Dale said, and the frequency response of the meter, cheap meters have rectifiers with very low frequency capability, and the signals on tracks are much higher frequency.
Another factor is that Marklin controllers have dead time in their outputs to receive the mfx signal from locos. This may also affect the meter reading.
Offline morsing
#11 Posted : 05 January 2020 21:58:20(UTC)
morsing
Ok, my meter appears to be rated up to 1KHz and Googling DCC says it's 10KHz.
Guest (8)
This page was generated in 0.363 seconds.
